Homebrew_PCBs
FYI: TT Heating Element ???
2006-01-31 by scratch_6057
If your building your own TT heating Press. . .
<http://www.sciplus.com/singleItem.cfm?terms=4640&cartLogFrom=Search>
The heating element from a common household iron. It runs on 120 VAC
and has (3) threaded hook-up terminals: the center is neutral, the two
sides draw 200 and 400 watts or use both for 600 watts. Surface
temperatures: 1250°F with 600 watts (5 amps), 1000°F with 400 watts
(3 amps), and 700°F with 200 watts (1.5 amps).
(Item Number 30783)
IRON HEATING ELEMENT $1.00
