Re: [Homebrew_PCBs] Re: PRess-n-peel blue
2006-01-22 by Kim Currier
Hi everyone. I purchased some press and peel Blue, and tried the first
board. I was not real pleased, but I am SURE it isn't the products fault. I
used the iron on the TOP of the mask plastic. I noticed that the center of
the board was not very good, but the outside edges were distinct, and sharp.
I was applying pressure on the board with the iron, and used a sheet of
paper on the top so that it would move freely.
I was wondering, should i pre-heat the board BEFORE I apply the
press-n-peel? Should I heat the board while I have it on TOP of the pores
and peel, or should I not press as hard as I did to make a good pattern turn
out on the board?
Thanks in advance!!
Kim
out on the board?
Thanks in advance!!
Kim
