Homebrew_PCBs
Archive for Homebrew_PCBs.
Printer quality
Printer quality
2005-11-25 by upand_at_them
Is a 600dpi (HP Laserjet 6L) printer a high enough quality for doing
toner transfer?
Mike
Re: [Homebrew_PCBs] Printer quality
2005-11-25 by whoop@blueyonder.co.uk
> toner transfer?
> Mike
Yes indeed.
John
Re: Printer quality
Good. I just bought one on Ebay.
Mike
> > toner transfer?
> > Mike
> Yes indeed.
> John
2005-11-25 by Stefan Trethan
>> toner transfer?
>> Mike
> Yes indeed.
> John
Second that.
Will work nicely for 0.5mm pitch ICs.
ST
2005-11-25 by Alan King
>toner transfer?
>Mike
Yep works well. For future reference, when it needs a new toner try
the $20 cheap replacement from Ebay. The clone cartridge I have
actually makes better boards more easily. Likely a lower melt point and
less fine toner..
Alan
Re: Printer quality
The refill kit, or a new cartridge?
Mike
doing
> >toner transfer?
> >Mike
try
point and
> less fine toner..
> Alan
Re: Printer quality
2005-11-26 by mikegw20
doing
> >> toner transfer?
> Second that.
I'll third that. Also ebay has some kits to fix it if it decices to
pick up all the pages at once.
Mike
Re: Printer quality
2005-11-27 by soffee83
--- In Homebrew_PCBs@yahoogroups.com, "mikegw20" <mikegw20@h...>
> > Second that.
>I'll third that.
That's funny, I just grabbed the same thing locally for transfers.
I've been fighting with a couple panel transfers on metal, so I
haven't had a decent chance to compare it to my previous one (Sharp
FO-2850). Good to see others have it as well.
The Sharp did good transfers, but I broke a roller in it with a
cleaning sheet and couldn't trust the feeds afterward, plus the
drivers stop at 98SE.
I'm not sure what toner is in this 6L, but I'll probably look for the
aforementioned generic when the time comes. I would have gone with HP
toner, as Tom Gootee (with the PCB toner site) recommended it over a
third party cartridge he tried. I'm also going to grab that HP feed
fix. This one definitely has that bug.
-George
PS- I've recently attached a smooth eighth inch aluminum plate to my
iron with JB Weld adhesive. It seems to make a noticeable difference
and gets a more uniform transfer, as well as taking care of the
problem with the steam hole voids. It hasn't been on there long, but
it looks promising.
Re: [Homebrew_PCBs] Re: Printer quality
2005-11-27 by Alan King
Note that his info was for an older HP printer, 300 DPI I believe.
The 600 DPI for the 6L is supposed to have ultrafine toner in the HP
cartridge, which is fine for printing, gives sharp edges and high
resolution. Little doubt the generics have lower res toner, probably
still passable for 600 DPI but thicker, and easier transfers. Likely a
little lower melting point than the HP toner too..
Alan
2005-11-27 by Stefan Trethan
> -George
I have had much trouble with cheap remanufactured toner in a old IIID.
Mainly the density was crap.
Much better with lexmark or HP brand ones.
ST
Re: Printer quality
Alan,
Thanks! Yes it was I recall. I think he was on a LaserJet4. I remember
looking at toner and I think the 3&4 had the same thing. Looks like
the 5&6 share a cart too. I'm not sure if they would use the same
stuff inside or not, but mine seems to do well with whatever is in
there. I think this one even does better with a slightly lighter
contrast. Luckily, the thick wide areas are the main things I usually
had trouble with on toner transfers and they were the easiest to touch
up if necessary. I'm planning to start cutting back on those anyway
and just masking the large spots with marker or doing hatch patterns
when I can.
Was there a particular generic you liked? Ebay had some $22 dollar
ones in a bright green, blue and white package, but there were also a
few others.
-Take Care
George
2005-11-28 by Alan King
>Alan,
>when I can.
>few others.
> -Take Care
>George
Can't tell, I don't see anyone with the picture of the cartridge as I
remember it. It had the cartridge partially open to show the drum, and
was green not the real high resolution blue. Likely one of the people
still selling them, but they've changed the picture.
I would imagine that most any of the cheap toners will be roughly the
same. The HP toner for 6L has a fine particle size, that is why it
lasts longer, you cover more area with the same total volume of toner.
The thicker cheap toner makes it a little easier to transfer, even when
it stays on the page some of it is more likely to have transferred.
Plus I'm pretty sure off the top of my head that the HP 6L cartridge was
spec'd to have a higher melting point toner, and for sure the cheap
stuff melts at the lower temps, so again a little easier to transfer
than the real 6L toner. Not that it can't work with the original cart,
but no sense paying extra for that when it's time to refil if the clones
work even a little better for transfer..
Alan
