Re: [Homebrew_PCBs] Advice on choosing the correct drill / stand for PCB dril...
2005-11-03 by JanRwl@AOL.COM
Ya know, it would SEEM that Dremel could install decent ABEC5  double-sealed
bearings, at least on the "chuck end" of their famous little  toy-drill, and
they'd have MANY more customers!  This is surely a good  example of the "Not MY
job!" syndrome!
2005-11-03 by Stefan Trethan
> double-sealed
> and
> "Not MY
> job!" syndrome!
they'd still have rubbish collets and runout.
you could easily replace the bearings, but, i know, that's not your job!
ST
Advice on choosing the correct drill / stand - Photos ?
2005-11-03 by Richard
Many thanks for all the views.
So the general consensus is to stay well away from any Dremel drill
due to lack of decent bearings & runout. I guess that rules out their
drill stand(s) as well, as only their drills will fit it...
The Minicraft drill stand appears to have a 'sideways' level (not
front-to-back) ?? - and also a tiny work area - so no good either.
If anyone can send me small pics of their drills/stands with a
manufactures name & price that would be a really big help !
Alternatively, how about a folder in the Photos section to show off
your setups ?
I've just taken delivery of the Velleman ET-20 etching tank, and
despite initial concerns about it's quality, it really does a fine
job of etching PCB's in super-quick time :)
Richard
<stefan_trethan@g...> wrote:
> > double-sealed
drill,
> > and
of the
> > "Not MY
> > job!" syndrome!
job!
> ST
In a message dated 11/3/2005 12:40:58 P.M. Central Standard Time,
stefan_trethan@... writes:
Yeah, it IS amazing a firm that manufactures such a "popular  thing" could do
it so BADLY for years!  A "Dremel tool" is hardly good  enough for
wood-carving!  If runout, etc. were not too bad for that use,  the longevity of the
device as-is from factory certainly is too short!  I  had one that gave-out before
"the pretty had rubbed off", and I needed such for  misc. shop stuff, so I
bought an "equivalent" from Sears.  Has lasted MUCH  longer, though has a clumsy
housing (the cylindrical simple shape can be adapted  to home-brew rigs much
more easily).
Re: [Homebrew_PCBs] Advice on choosing the correct drill / stand - Photos ?
On Thu, 03 Nov 2005 20:04:30 +0100, Richard
> your setups ?
<http://trethan.at.tf/pub/img1/drill_left.JPG>
that's my setup. manufacturer is me, and price is zero.
Actually, i modified it slightly. Put the bearings down in line with the
table so that there is no sideways movement but a precise arc.
Note that this driller was prepared for a projection mechanism which was
never fitted. Without that you can use a simple piano hinge.
ST
Re: Advice on choosing the correct drill / stand - Photos ?
Wow :-0  - that's an amazing setup, ST !!
From your picture, I'm guessing you chose this system because it
allows you to drill HUGE boards ?
It certainly looks very solid and easy to use..
Nice job - most impressed :)
Richard
with the
which was
> ST
Re: [Homebrew_PCBs] Re: Advice on choosing the correct drill / stand - Photos ?
On Thu, 03 Nov 2005 20:51:08 +0100, Richard
> Richard
no, not at all. I chose this setup because there must be a certain
arm-length to approximate straight movement with a pivoting action. Also,
in order to minimize sideways play, the bearings must be apart some
distance. So that more or less gives a minimum size. Also, the bottom
plate and table was one piece initially, and i only needed one cut on it.
There is now a neat space under the table for drills, and the hoover
nozzle is fixed to the arm, as well as a small lamp. Not sure if i add the
projection mechanism one day.
ST
> could do
> longevity of the
> gave-out before
> I
> a clumsy
> much
> more easily).
When you put in a grinding disc in the cheap tools, it will sometimes
break just from the chatter of the runout.
No comparision in using the proxxon grinder and a cheap one. All the tools
work just so much better when they cut all-round.
ST
On Thu, 03 Nov 2005 21:02:13 +0100, Stefan Trethan <stefan_trethan@...>
> the
> ST
Oh, and there's a counterweight at the back to balance the arm neutrally
now, and a screw parallel to the drill as a stop. I found it helpful
having the stop actually land on the PCB, it holds it down im just that
critical moment when the drill breaks through.
I would do some things different now, mainly use a simple flat bottom
plate, and a triangular pivoting plate, with a piano hinge at the back.
This would be much stiffer than the open frame i have now.
ST
Richard:
Not meaning to confuse you with differences of approach, but  here's what I
did in this regard.  The drill-motor is a 400 Hz. 3-phase  "aircraft instrument
motor" with some serious machine-work on it so I had a  collet on the "shaft
end".  I built the 400 Hz. generator (95 W.)  myself.  Not really difficult.
The CNC control is no longer done by  the PET you see in the photo, but by a
typical PC (only, since uses only  GWBASIC, an old '386 works fine!).  Jan
Rowland       _Yahoo!  Photos - View Photo_
(http://photos.groups.yahoo.com/group/homebrew_pcbs/vwp?.dir=/JanRowland&.src=gr&.dnm=Home-Brew+CNC+PCB+Drill.jpg&.v
iew=t&.done=http://photos.groups.yahoo.com/group/homebrew_pcbs/lst?&.dir=/JanR
owland&.src=gr&.view=t)  (If you can't get the pic by clicking on that, it is
in  the PHOTOS section under MY name)
In a message dated 11/3/2005 3:10:49 P.M. Central Standard Time,
JanRwl@... writes:
(_http://photos.groups.yahoo.com/group/homebrew_pcbs/vwp?.dir=/JanRowland&.src
=gr&.dnm=Home-Brew+CNC+PCB+Drill.jpg&.view=t&.done=http://photos.groups.yahoo.
com/group/homebrew_pcbs/lst?&.dir=/JanRowland&.src=gr&.view=t_
ew+CNC+PCB+Drill.jpg&.view=t&.done=http://photos.groups.yahoo.com/group/homebr
ew_pcbs/lst?&.dir=/JanRowland&.src=gr&.view=t) )   (If you can't get the pic
in  the PHOTOS  section under MY name)<<
I tried simple "clicking-on" and discovered a mess.  I  tinkered a bit, and
found that if you copy/paste JUST this part:
_http://photos.groups.yahoo.com/group/homebrew_pcbs/vwp?.dir=/JanRowland_
(http://photos.groups.yahoo.com/group/homebrew_pcbs/vwp?.dir=/JanRowland)
in your address-slot, that will bring up the photo  desired.            SORRY!
2005-11-05 by jos_28122002
Piano hinge - EXCELLENT idea, ST.
I bought a ready drill stand, but the damn thing has awfull
sideways movement when you lower the drill to make a hole.
Making one of these items should solve that issue.
Thanks for that pic. Looks very practical.
But how do you raise/lower the drill to make the holes?
John
> Richard
> with the
> which was
> > ST
2005-11-05 by Stefan Trethan
On Sat, 05 Nov 2005 11:48:23 +0100, jos_28122002
> John
With my left hand.
The drill is balanced with a counterweight not on the picture.
Usually i lift it with the back of my hand, using the fingers to aid in
positioning the board, much easier with two hands.
Gravity pulls the drill down. Also i use a wood block under the PCB,
simply because i found the flat PCB hard to position.
Another hint, if you break drills not quite down to the taper but with a
little section of the narrow part remaining those are great keepers for
holes where you can't hold the board steady properly. Say for a forgotten
hole you notice after populating or widening holes. If they are short
enough they won't break even if you hold the board freehand. You needn't
grind them, any break will still cut enough.
ST
