Homebrew_PCBs
Archive for Homebrew_PCBs.
Advice for newbie please!
2005-10-28 by andrew566020
I'm about to attempt my first homemade pcb after many years of using
breadboards and veroboard for my electronics tinkering!
I've recently joined the group and have been avidly reading the recent
posts and the archives. I do however have a few questions...
Many of the posts I've read advise against the use of an iron and
recommend a laminator instead. Because of this I went looking for a
suitable model. It struck me that many of the laminators for sale were
quoting maximum thicknesses of 250 micron (1/4 mm), this doesn't seem
nearly enough capacity, am I missing something?
Also I intend buying a laser printer. The HP laserjet 1022 is a budget
model that is reputed to have high quality output. Would this be a
reasonable starting place or should I look elsewhere.
Sorry for the dumb questions but I really am at the bottom of this
learning curve so any help would be welcome..
Andy.
Re: Advice for newbie please!
2005-10-29 by mikegw20
--- In Homebrew_PCBs@yahoogroups.com, "andrew566020"
<andy.jrhall@b...> wrote:
> Hi,
> [snip]
Welcome to the fun. I swore off veroboard in a fit of anger and have
never looked back.
With respect to a laminator, I started with an iron and to be honest
I have not bothered to 'graduate'. I suspect that a laminator is
superior for larger boards but my boards are less than 50mm x 50mm.
In the past posts and links you will find information on how to
modify a laminator, by this you can open up that gap to fit a board.
Regarding the printer I have a dodgy old laserjet 6L which suits me
fine, again I have heard that certain printer/paper combinations are
more important. Remember that the laser printer at work is always a
good start. Take a look at the group's database link on yahoo and
there is info about paper and printers.
The first thing you will have to do is find the best paper for
yourself. This will depend on what country you are in. It seems
that us Australians have been blessed with the best paper in that I
don't even need to soak the stuff off the board, it just peels off.
Make up a test pattern with lots of thin and thick traces and
practice your technique. Don't bother about etching until the trace
looks good. You can always clean the toner off with some turpentine.
I find that a layer from top to bottom: pcb,toner paper, two sheets
of toilet paper, printer paper, iron. Works for me, the two bits of
toilet paper are there to account for any bumps in the board or the
iron. I press hard for 30 seconds , turn the iron 90 degrees 30 more
seconds... For a single sided board I do this for 2 minutes. A
double sided each side gets 90 seconds.
Another thing you should consider in making your own boards is moving
to surface mount components. It is far easier than I thought it
would be and drilling all the holes will quickly get anoying.
Hope this helps
Mike
2005-10-29 by Chris Horne
If its any help, I can only relate what I do.
I do a dozen or so 8" x 5.5" boards a week and I still use an Iron..
the same one my wife uses to do the ironing.
(more important toys to buy !)
I use an HP 1010 laser at 600 dpi to print on press-n-peel sheets
it works a treat... ---
I clean the boards with 600 wet and dry, rinse and dry them
Then iron on (middle steam heat, without the heat)
with a single sheet of ordinary white paper between the iron and
press-n-peel.. I iron for about 1.5 minutes
Then quench under the tap and peel the sheet off
The process work fine for the boards I do, I get 98% success rate
and I'm not going to mess with a process that works !
The biggest pain was hand drilling the holes..
if you are doing Fibreglass, you need to buy carbide bits
I use mostly paper boards but still use carbide bits, they last 10's
of times longer.
Chris
In Homebrew_PCBs@yahoogroups.com, "andrew566020" <andy.jrhall@b...>
wrote:
> Hi,
using
recent
were
seem
budget
> Regards,
> Andy.
2005-10-29 by andrew566020
> never looked back.
<SNIP>
Hi Mike,
Thanks for taking the time to help me out! I see from your response
that laminators probably need to be modified before they can be used.
I guess that answers my question about the material thicknesses.
It sounds like you are having good results with your iron and you've
certainly given me the confidence to have a go myself. I guess I was a
bit nervous about using an iron with the press n peel I bought as it's
a little expensive to waste. While I'm experimenting I guess I could
have a go with some ink jet paper as well, it's cheap to try after all.
Surface mount components are something I hadn't considered using. I
guess making pcbs creates many new possibilities.
Best wishes and many thanks,
Andy.
Hi Chris,
Thanks for helping with my question. That's two votes for using an
iron. Mike also responded saying he has success with the 'iron
method'. I guess that I'll do some experimentation for myself and see
how I get on.
Do you move the iron around (as if ironing a shirt) or do you apply
heat and pressure in one place for a while then lift and move the iron
somewhere else?
Best wishes and thanks,
Andy.
--- In Homebrew_PCBs@yahoogroups.com, "Chris Horne" <chris@s...> wrote:
> Hi,
> of times longer.
> Chris
> wrote:
> > Hi,
> using
> recent
> were
> seem
> budget
> > Regards,
> > Andy.
Re: [Homebrew_PCBs] Advice for newbie please!
2005-10-29 by Stefan Trethan
On Sat, 29 Oct 2005 01:50:48 +0200, andrew566020
you need to modify most. You can also use a fuser from a dead
printer/copier, but you might need to modify that too.
Usually it's only a matter of removing some spacer or filing something or
adding something, should not be a problem for anyone with basic mechanical
skills. If you are one of those people that can't even assemble flatpack
furniture (i do believe they only exist on TV, nobody can really be that
stupid), get a laminator that accepts boards already (doesn't pulsar sell
one??).
ST
2005-10-29 by Mike Young
Yes, Pulsar sells a laminator, but won't be shipping new orders until 11/7.
I was just cruising their site last evening. I am also a newbie, and looking
to get started. In general, are their transfer products the ones to use? Is
their package deal a good price? $100US for the starter kit seems not
unreasonable; $50 for the kit without the laminator.
I also read their recommendation to use 1/2 oz cladding, rather than 1 oz.
They make a pretty compelling argument, but I'm somewhat partial to the 1oz
FR4 boards I've been using (commercial boards). Will I have problems holding
under 10 mil separation with the 1 oz?
Their 1-minute sponging technique sounds almost too good to be true. Is
anyone having success with that? (There's a lot of mention here of tanks,
aerators, and heaters.) I would just try it and see, but as I'm totally new,
I would very much like my first board to be a brain-dead simple success.
(Seeing as I'm new and don't have tanks and things, there doesn't seem to be
much other choice. :) Are good results with 10 mil traces and spacing
possible, even if not likely, on the first try?
Also, I notice that RadioShack's website doesn't know anything about "ferric
chloride", or "pcb etch". You'll find the MSDS for their part number
26-1535, but it does look like RS now only panders to cellphones, ipods, and
TV wiring.
One last question: which is worse? singleside SMT with some air wires, or
double side with a bunch of drilling for vias and through-holes?
> one??).
2005-10-30 by andrew566020
Hi Stefan,
Thanks for the reply,
I think I probably could do the necessary modifications but several
responses to my question have indicated that an iron is ok for smaller
boards. I think I might try an iron first then move up to laminator as
confidence/funds permit.
Andy Hall
something >
> ST
2005-10-30 by lcdpublishing
NO! NO! NO!
DO NOT MOVE THE IRON! Be very careful and only apply presure
downwards. Then if you have to move it, pick it straight up and
move to new location, then straight down again. Any sideways
movement while pressing will cause smears.
I have also been taking very small pieces of tape and taping the
paper to the PCB to help keep it where I want it while pressing.
Chris
> Hi Chris,
see
> how I get on.
iron
> somewhere else?
> Andy.
wrote:
> > Hi,
Iron..
10's
> > of times longer.
> > Chris
<andy.jrhall@b...>
> > wrote:
> > > Hi,
> > using
> > recent
and
for a
sale
> > were
doesn't
> > seem
a
> > budget
be a
this
> > > Regards,
> > > Andy.
2005-10-30 by Norm Stewart
>TV wiring.
Radio Shack needs to change their name to " The Telephone Booth". They
are systematically getting out of the hobbiest/experimenter/parts
business in favor of slick consumer goods.
Norm
Re: [Homebrew_PCBs] Re: Advice for newbie please!
2005-10-30 by Stefan Trethan
On Sat, 29 Oct 2005 13:02:43 +0200, andrew566020
> Hi Chris,
> how I get on.
> somewhere else?
> Andy.
You can certainly try with the iron first, it is usually free to use if
you wait until the owner is out of the house.
I use the iron for maybe 5 boards, at first it was OK, but then i just
couldn't get good results any more. Use the fuser ever since and never
looked back.
ST
On Sun, 30 Oct 2005 20:08:39 +0100, Norm Stewart <normstewart@...>
> Norm
Ask them if 500 milliamps is the same as 5 amps.
But plan in some time, they will need a piece of paper, a pencil, and some
headscratching to conclude in a positive answer.
But don't worry, while we don't have any shacks here the parts stores are
no better. Don't sell phones but don't sell no parts neither. I'm surely
better stocked than some of them.
ST
2005-10-30 by Alan King
>>TV wiring.
>Norm
They had major clearances and relaunch of target market this month, no
doubt going to more profitiable items than hobbiest stuff. Had tons of
good clearance deals that even the employees didn't know the new prices
too, should have seen the look on the guys face when my last of the $129
DVI cables rang up for only $12, not bad for high quality local.
Alan
2005-10-31 by mikegw20
--- In Homebrew_PCBs@yahoogroups.com, "Mike Young" <mikewhy@s...> wrote:
[snip]
wires, or
Anything that cuts down on drilling is good by me. I do double sided
smt with some vias made with a bit of copper wire if space is tight.
If you are feeling cheeky you could just put big pads in and solder
your jumpers to them without the hole.
In my opinion drilling is the worst bit of diy as it is the one job
that gains no/minimal efficiency the more boards you make. Everything
else like etching and cleaning gets more efficient if you do batches of
boards.
Additionally I have found that double sided smt is easier to design
that double sided through hole as you are not forever dodging pads.
Mike
2005-10-31 by Alan King
>boards.
>Mike
Second on everything said, it is the way to go. You can do a whole
lot even just single sided SMT with less jumpers than you'd think once
you get used to that kind of layout.. When you need double sided, take
connections out to the edge of the board above one another, and just
solder a wire around the edge of the board, no drilling involved. Need
a bus, just take 8 or 10 out over the other 8 or 10. and have an extra
piece with the 8 or 10 parallel tracks. Cut straight along that edge,
hold up your extra piece, and run a solder ball down both sides to make
the top to bottom connection. Easier than doing 1 or 2 seperate vias.
Or space at .1", and use header pins or similar for the top to bottom
join. Lots more ways to do many connections across the edges with no
drilling once you start doing it a bit more too.
And not going through hole does help a great deal. I've redone most
of the Eagle TTL chips as SMT pads, and just solder them to the top of
the board. Adds a lot to your useable space when you can route whatever
you need on the other side without pin interference. Almost no parts
really need to go through the board for normal use. Still nice to have
a driller but I use it more for mechanical stuff than drilling boards now.
Alan
2005-10-31 by Mike Young
> the board.
Now there's an idea. Can you email me your part lib? Just the ref-packages,
or wherever you put the package definition will do it.
2005-10-31 by Chris Horne
I do move the iron, butonly when the board is too big to just leave
it in one spot...
The way I do this is tolay a sheet of plain white paper over the
press-n-peel
Then start by holding the iron in one spot with my right habd.
I then push down on the sheet of paper (where it is not over the
board) which seems to lock everything in place..
I then move the iron round slowly, keeping my pressureon the paper..
I think it'simportant to have the paper when moving the iron, it
stops the tranfer sliding on the board.
Also, the times have to be increased proportionally to compensate
I do allmy boards this way, I don't have any small enough to do with
the iron stationary.
Cheers
Chris
> Hi Chris,
see
> how I get on.
iron
> somewhere else?
> Andy.
wrote:
> > Hi,
Iron..
10's
> > of times longer.
> > Chris
<andy.jrhall@b...>
> > wrote:
> > > Hi,
> > using
> > recent
and
for a
sale
> > were
doesn't
> > seem
a
> > budget
be a
this
> > > Regards,
> > > Andy.
2005-10-31 by Stefan Trethan
>> Mike
What i like to do is single sided mixed population.
I put connectors and some ICs on top, and passives, transistors, and some
small ICs on the bottom.
This can result in a very tight design, with no vias. I don't think SMD
only single sided can be made that small.
Also, i want to have connectors and stuff with leads, so they are well
secured to the board.
It gives you the opportunity to put labeling on the top side, not so much
for components, but for pinouts and stuff like that. With all the passive
"underbrush" on the bottom there's usually enough space.
SMD definitely must not be ignored for homebrew PCBs, it has too many
advantages. But for me SMD only would in many cases not be very practical.
ST
2005-10-31 by bob_ledoux
Look at the Pulsar.gs site. I use their products for my occasional
boards and never have a failure. I bought the GBC laminator locally.
Their sponge etching method works great.
> Hi,
> Regards,
> Andy.
2005-10-31 by andrew566020
> it in one spot...
<SNIP>
Hi Chris,
So it is safe to move the iron as long as something stops the transfer
film from moving.
Great stuff, I'll give it a try!
Many thanks,
Andy.
<SNIP>
Hi Bob,
I have already seen the site. It looks very good with lots of good
info. I now have access to a GBC 40P laminator which presumably will
require some modification before it can be used. Did you modify your
laminator? If so, is it difficult?
Cheers,
Andy.
>>>Mike
Eagle also has some DB style connector layouts that are for board
edges, with board fitting between the two pin rows on the back of the
connector, 1/2 pins on top and 1/2 pins on bottom. Is a very good,
secure method still with no holes, and you can do similar with 2 row pin
headers etc sticking out from edge. Between that, top mounting dip
style chips, and wrapping traces over the edges, I hardly ever drill a
hole in anything now, no pins as well as vias. Just so much easier to
not have to get out the drill and have dust, even with CNC.. Even when
I have boards made now, I'm starting to top mount the DIPs and do edge
type connectors, it just makes things a bit easier.
Alan
> Alan
While i also use the edge-on D solder cup connectors they still give you
some of the signals up top and some one the bottom layer, kind of a little
drawback. Bending traces over the edge is a interesting idea, might just
try that.
Drilling is nasty, yes, but not _that_ bad. As long as i don't have to
drill hundreds of holes that's ok with me.
ST
2005-11-01 by Alan King
>>Alan
>try that.
Yep they are not perfect, but fortunately for LPT and serial port most
of the important signals are on top, usually only 2 or 3 wires the
bottom. At first I did the bending literally, with wires soldered on
one side and bent to the other. Much faster to just use header pins or
something else straight, run solder down the pins/traces, and make
fillets, so definitely start from there. There used to be lots of
commercial equipment made this way, BMW stereos had boards soldered on
edge to other boards like this, with many traces making the 90 degree
solder connection. Often needs a resolder after even a small impact
like a deer or something, because of the inertial effects breaking some
joints.
Oh yes, as always minimize work, but still stay flexible when doing it
to take best advantage. Even though it's very good to avoid as much as
possible, a via hole here and there is still sometimes better than
trying to get every last signal to an edge of the board. But once
starting with the idea in mind, I can usually get it to only needing a
jumper here and there, and just wire a few top to bottom instead of
getting the drill out.
Alan
