Ideas (stupid??) for toner transfer
2005-10-17 by mikegw20
Helo all.
I just had a few random thoughts about toner transfer and I wondered if
anyone has tried them.  I am using an iron with a good level of success
as the boards I am using are quite small.  However, I read that many
people prefer the laminator to supply heat and pressure.
So I was letting my mind wander with heat and pressure and the thought
about sandwich presses (obviously you would need a flat plate) and
shirt iron presses (I am not sure of the proper name but the things
that iron a whole shirt in one pull of the handle)?  The disadvantage
would be the size, but both would require no modification unlike some
laminators.
Has anyone tried either of these two?
Mike
Re: Ideas (stupid??) for toner transfer
2005-10-17 by lcdpublishing
MIke,
That isn't a bad idea at all - I have not tried it myself, but while
ironing some boards this weekend, I was thinking of something very
similar.
The presure is important in this process - and it must be even
presure which means there has to be something between the heat
source and the PCB to deal with any high spots so you get even
transfer. CUrrently I use a heavy duty paper towel for
this "padding".
Heat is another key element - I have been have good luck at 360
Degrees F for my paper.  So the press would need to create the
proper amount of heat - evenly across it's platten.
When using the Iron, it is very easy to mess up in a couple of
areas....
1) Not getting a transfer where the steam holes are in the iron - I
usually press 10 seconds, move the iron, press another 10 second to
make sure I avoid the steam hole problem
2) No sideways movement when pressing.  This is a problem when the
transfer paper slides sideways during the pressing and smears the
toner.  Pushing straight down with a good amount of force is harder
than it seems.
3) Having to press several times because the iron is not big enough.
So, while pressing this weekend, I was thinking of the same thing, a
T-Shirt press for Iron on transfers.  I expect that they are
expensive though.  Making one mechanically should not be all that
difficult.  The heating element is the big problem - you need even
heat across the whole surface and I have no idea how to make a
heating element :-(
So, in my opinion, you don't have a crazy idea!
Chris
--- In Homebrew_PCBs@yahoogroups.com, "mikegw20" <mikegw20@h...>
wrote:
> Helo all.
wondered if
success
many
thought
things
disadvantage
some
> laminators.
> Mike
Re: [Homebrew_PCBs] Ideas (stupid??) for toner transfer
2005-10-17 by microsoftwarecontrol
to me, pid controlled laminator is an unbeatable solution.
  Sent: Monday, October 17, 2005 8:01 AM
  Subject: [Homebrew_PCBs] Ideas (stupid??) for toner transfer
  Helo all.
  laminators.
  Mike
  Be sure to visit the group home and check for new Links, Files, and Photos:
  http://groups.yahoo.com/group/Homebrew_PCBs
  If Files or Photos are running short of space, post them here:
  http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
  SPONSORED LINKS Electrical engineering degree online  Electrical engineering degree  Printed circuit board
        Electrical engineering  Electrical engineering course  Electrical engineering graduate school
  YAHOO! GROUPS LINKS
    a..  Visit your group "Homebrew_PCBs" on the web.
    b..  To unsubscribe from this group, send an email to:
     Homebrew_PCBs-unsubscribe@yahoogroups.com
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2005-10-17 by Steve
On my copious "to do" list.
I have a Tshirt press and I bought a used HP 6L, and a couple of
laminators, and I found this little sandwich press (very flat) quite
some time ago. Someone here was going to send me a few sheets of their
favorite paper but I guess he forgot, so I need to pick up something
to try.
For pressing dye sub onto tiles, they make a thin sheet of silicone
rubber to place between the press and the tile. The press is very
flat, it is the tiles that are uneven. It does make pressing take
quite a bit longer. I suspect it would not be that necessary with a PCB.
My "to do" list is about a mile long, though...
Also, unless you already have a Tshirt press, it's a spendy way to do
toner transfer. "Cheap" Tshirt presses don't have a temp control and
cost about $250 and are a bit bulky compared to a laminator.
I've heard of people bolting a sheet of aluminum onto an old iron to
get rid of the steam hole problem.
Steve Greenfield
--- In Homebrew_PCBs@yahoogroups.com, "mikegw20" <mikegw20@h...> wrote:
> Helo all.
> laminators.
> Mike
Re: [Homebrew_PCBs] Re: Ideas (stupid??) for toner transfer
2005-10-17 by dbarlow@bobdbob.com
Quoting lcdpublishing <lcdpublishing@...>:
> heating element :-(
I have an approximately 5 by 7 inch stainless cooler block from
an old electrophoresis cell.  I was thinking it could be fed
steam from a coffee maker element instead of water to make a heat
block.
Unfortunately I also have too much on my plate to play with it.
(And I have a couple laminators already.)
If anyone wants to do the work I'd be happy to mail it to them.
-Dan Barlow
This message was sent using IMP, the Internet Messaging Program.
2005-10-17 by Steve
--- In Homebrew_PCBs@yahoogroups.com, dbarlow@b... wrote:
> Quoting lcdpublishing <lcdpublishing@y...>:
> > heating element :-(
> block.
It would have to be live steam, so it'd take more than a coffee maker
element.
BTW, noncontact pyrometers are about $40 to $50 at Sears. Online I've
seen them as cheap as $25. I use one to check my Tshirt press. Very
handy. Make sure you get one that goes up to about 600F.
Steve Greenfield
2005-10-18 by Alan King
  A good electric griddle/grill might do very well here, along with a
jack and some hardware.  Think of an old screw type printing press..
Might be an excellent idea, especially since the grill could do double
duty for reflowing SMT boards.
Alan
2005-10-18 by Tony Smith
>  Alan
Tom Goottee (spelling?) did something like this a while back (check the
archives).  Not a simple as it sounds, he had a few hassles getting even
pressure over the board.  I think he got it sorted out eventually.
http://www.sparkfun.com found SMT on a hot plate worked better than their
reflow oven.
Tony
2005-10-19 by Stefan Trethan
> Alan
you will probably run into more trouble (uneven pressure and heat) than
you get advantage over a laminator/fuser.
The thing is, pressure, as in force per area, depends, well, like on area.
In a fuser/laminator you only have a "line" thus 1-dimensional
relationship between boardsize and pressure.  In a press you have that
squared, which could be another problem.
ST
2005-10-20 by Steve
area.
Very good point. I doubt an electric griddle could stand up to much
pressure, too.
Steve Greenfield
2005-10-20 by Alan King
>area.
>pressure, too.
>Steve Greenfield
  A ton or two may be closer than you'd think off hand, remember the
rollers flatten out a bit and create a contact patch.  Not sure extreme
pressure is really important, with correct heat the toner should flow
without that much pressure.  Reinforcing a plate is easy enough, and
actually had thought of using a levered hand roller like in the manual
tile cutter I used last week.  But probably too much work to keep the
board and print aligned that way..  Just worth investigating a bit,
since the griddle is useful on it's own for SMT reflow anyway.  If it
can be made to work it'd be great, if not there is no real loss either..
Alan
2005-10-20 by lcdpublishing
Hmm, this is a good point so it bears checking on.  I currently use
a clothes iron and press it by hand and use about 5 inches square of
the sole plate at any one time.  I weigh about 225 pounds these days
and am pushing down on the iron with a fair amount of force - lets
say half my weight 112 pounds - which I am sure is more than I am
pushing down.
5 x 5 = 25 sqaure inches of surface area
112 / 25 = 4.48 pounds per square inch
This has worked very good for me so far (although I suspect I have
beginners luck).  So, a 12" x 12" board would require
12 x 12 = 144 square inches x 4.48 pounds per square inch = 645
pounds of presure on that plate for a large circuit board.  This
would be pretty hard to achieve without some form of mechanical
advantage (unless I keep putting on weight since I quit smoking!)
Chris
like on
> >area.
have that
much
> >pressure, too.
> >Steve Greenfield
extreme
flow
and
manual
bit,
it
either..
> Alan
2005-10-20 by Stefan Trethan
On Thu, 20 Oct 2005 21:58:52 +0200, lcdpublishing
> pushing down.
> Chris
My worry was not so much about the magnitude of pressure in general, but
how to adjust if from board size to board size.
With the fuser i can choose to let the wide or the narrow side run
through, thus i can keep the "length" in the fuser similar with all the
different boards i make. I have not found variations of a factor 2 or even
3 a problem. The rubber roller is doing a pretty good job at keeping
things in contact.
If a press should work, i think it must have a rubber plate below the
board, a rigid material both sides will probably cause trouble. Also, i
would be afraid of temperature patterns, they can be quite extreme with
heating elements that are concentrated in one area. A pressure gauge could
be made easily, just take the bathroom scale and put it between the press
plate and the screw/lever you use to tighten it.
At this point, i'm just not seeing the advantages.
But you know - never listen to the nay sayers. Look at the arguments why
it mightn't work, fix them, and do it.
ST
I agree completely about the two primary points -
1) Rubber or some other material that gives to compensate for board
thickness variations
2) un-even heat from the element - this would be the biggest problem
to correct I believe.  The only thing that comes to mind is to have
a thick metal plate on the heating element side of the press.  Then,
to use it, turn it on and let it get good and hot prior to use.
Even then, I still think there is going to be some problems with
some areas being hotter than others.
My brother in-law is a garage sale junkie.  I will describe to him
what I am looking for and he will find one for a couple of bucks
somewhere - that's worth a try :-)
Chris
use
square of
days
lets
> > pushing down.
have
> > Chris
general, but
run
all the
or even
keeping
> things in contact.
Also, i
with
gauge could
the press
arguments why
> ST
2005-10-20 by Tony Magon
An easier way is to warm up the copper first with a hair dryer, before
putting  the the paper with the toner on it , and then use the iron.
Regards
Tony VK2IC
>Chris
>use
>square of
>days
>lets
>>>pushing down.
>have
>>>Chris
>general, but
>run
>all the
>or even
>keeping
>>things in contact.
>the
>Also, i
>with
>gauge could
>the press
>arguments why
>>ST
>Yahoo! Groups Links
2005-10-20 by mikezcnc
You know Stefan, I had zero problems since I started using a
laminator. It works predictably every time and when I tried ironing
TT, it was a nightmare for me. With presses I had never any luck.
I saw an interesting solution somewhere on the net: a guy placed an
iron upside down and placed the PC on top of it. Then he loaded heavy
weights on top of it. Apparently that process allowed him successful a
TT. Mike
2005-10-21 by Stefan Trethan
On Thu, 20 Oct 2005 22:51:20 +0200, lcdpublishing
Yes, some silicone rubber maybe. I guess one could take RTV silicone and
spread it evenly.
Or a baking sheet, maybe several if not thick enough.
Well, a thick copper or aluminum plate would certainly help. There are
also heating foils to stick on a plate which should heat fairly evenly
(probably colder at the edges). Someone here tried one of those some time
back, and a ingenious pressing force mecanism consisting of a lever and a
bucket with weights i think. I do not know what came of it, the machine
was finished (i've seen a picture), but i don't know about the results and
it was probably pre-HD crash so i can't find it.
I know for fact that the heat in things like electric contact toasters or
waffle irons is not even.
Also, i inspected a clothes press and deemed it not even worthy of trying.
The guys using a skillet for SMD reflow also mention a heat pattern where
the element is.
I guess avoiding it by even heating as far as possible is better than
fighting it. But hey, maybe it isn't even a problem...
> Chris
Sure is.
I'm just frightened it brings back some of the problems i had with the
clothes iron, so i'll stick with my fuser for now.
ST
2005-10-23 by Steve
--- In Homebrew_PCBs@yahoogroups.com, "lcdpublishing"
A Tshirt press has exactly this. They use a silicone rubber foam. And
it is possible to buy sheets of it if you are making your own press.
Growing up, Sunday morning breakfast was usually cooked on an electric
griddle with a simple 3/4 circle of heating element on the bottom. You
could clearly see on the bottom of pancakes where it was hotter.
However, my commercial Tshirt press, to my great surprise, had
essentially the same pattern for the element. Yet it holds very good
temp across the whole thing.
The differences:
1. Bottom of the griddle is open to the air, the top of the Tshirt
press platen is well insulated with fiberglass under a thin metal top.
2. A water filled pancake has a fairly high heat capacity.
3. The griddle is very thin, whereas the Tshirt press platen is very
thick.
BTW, common practice in the past was to paint/anodize them black on
the theory of increased heat transfer, when in fact that only helps it
-radiate- heat. Now many heat presses are anodized natural aluminum,
or painted white.
Keep in mind this prevents a pyrometer from getting an accurate temp
reading. However, it makes it -much- more comfortable to work in front
of it! I picked up some white porcelain 1200F engine paint to repaint
my Tshirt press.
Steve Greenfield
2005-10-23 by Stefan Trethan
> or painted white.
Right, many are black, all sorts of grills too.
Never noticed how silly that is.
ST
