Silk Screen Printing overlays
2005-09-22 by Andrew Mawson
2005-09-22 by Stefan Trethan
> Has anyone got a homebrew set up working for printing componenti do toner transfer it.
> location overlays? Any tips and gotcha's ?
> Been toying with the idea of making a small screen printing set up
> but
> no point in re-inventing the wheel if you've been there before!
> AWEM
2005-09-23 by ron amundson
> Has anyone got a homebrew set up working forIts rare that I will add the overlay, but I do have
> printing component
> printing set up
> but
> there before!
> AWEM
2005-09-23 by Adam Seychell
>>printing component
>>printing set up
>>but
>>there before!
>>AWEM
> the capability of doing so.
> Here are a few things I found.
> 1. Use orange screen, as it reduces ghosting due to
> reflections as compared to white. (I still mostly use
> white, as its what I bought at the start)
> 2. One might get better results using sheet emulsion,
> but I have found that manually coating the screen
> works pretty well. The key is to only make one pass
> with the emulsion on front side, and then on the back
> side. If you make multiple passes, the emulsion gets
> too thick, and you loose resolution.
> 3. Be sure to refrigerate your emulsion... most of
> them have a short shelf life, and when they go bad,
> you run into big problems.
> 4. Don't be cheap when it comes to emulsion remover.
> While one can use bleach and scrubbing, the commercial
> removers work wonders, and I think are a lot easier on
> the screens.
> 5. A Stouffer gauge is a good investment, even for
> making PCB's. Spending $US18 for a strip of plastic
> seems insance, but it will save you tons of scrap
> screens, pcb's, and time... The 21 step is what was
> recommended to me, and its amazing.
> 6. Wash out your screen when you are done... if you
> wait around... it becomes pretty much permanent
> 7. scrap pcb's work well for registration
> 8. Water soluble inks make for ease of cleanup, but
> are not as robust as some of the solvent based inks
> 9. I use student grade art supplies, as most of the
> time, they are a lot safer than the industrial inks
> and solvents.
> 10. Currently, I make my films using ink jet printed
> transparencies. The black is not as opaque as would be
> nice for optimum resolution, so I am thinking of
> getting some ortho film or something like it.
> 11. Wood screening frames warp... but I have yet to
> find a good source of aluminum ones. A warped frame
> makes it a challenge to get decent resolution.
> Silkscreening just overlays is a ton of extra messing
> around for not a lot of value imho. However, you can
> also make up soldermask, solder stencils, and
> enclosure screens at the same time. The net result is
> you save a lot of time and increase reliability via
> reflowing the boards vs hand soldering, so imho its
> usually worthwhile.
> Ron
2005-09-23 by Bob_xyz
> Thanks Ron the informative reply.around. I
> Silkscreening a one off PCB is like I figured, lots of messing
> suspect it would add another hour to two of labor.it as
> I bought some silkscreen emulsion once, in a futile attempt to use
> a liquid photoresist for etching PCBs. First, I could not get thineven
> coatings, and 2nd the cured emulsion is not resistant to etchants
> (swells and lifts of copper). Just letting others no it ain't work.
> Adam
> Adam - What emulsion did you try and what was your etchant? I seem
> to recall a discussion on this topic recently but I'm not sure any
> conclusions came of it.
> Ron - Thanks for all the info on screening.
> Regards, Bob
> --- In Homebrew_PCBs@yahoogroups.com, Adam Seychell
> around. I
> it as
> even
>>Adam
