Tinning with solder paste....
2005-09-08 by lcdpublishing
This worked very well for my first try. I purchased the solder paste from Mcmaster as specified by Derek. I thined it a little bit too much with water though, so be careful there. I used a glue brush (you folks probably call them acid brushes) to flow out the paste. Hit it with the heat gun moving around pretty slowly. At first I couldn't see anything happening so I held the gun stationary too long which turned the board a tint of brown. To help see what is going on, I placed a light on the right side of the board, heat gun over the board, and looked from the left side. After doing this I could see the solder melting and joining together on the traces. I coated and heated about 4 or 5 times and I think I got 99% coverage on the traces. After washing thoroughly, I polished it with scotchbright and it looks pretty good. So, from a newbie point of view, it isn't that difficult to do. Also, one more very interesting thing I noticed. You know that smell of a new car, well, if you are using the same solder paste as I did, let me know if you think you have a new car there :-) Very unusual, it really smelt like a new car - I just wish I could afford one! Chris
