Homebrew_PCBs
Ferric Chloride etching questions...
2005-09-07 by lcdpublishing
Okay,
I am about to take my first "real" etching tank for a test drive
today. There are a number of "Firsts" in this for me.
1) I am working with the powder, according to the directions, I add
the powder to the water - 1 pound / 1/2 gallon. They caution to add
it slowly as it could react and bubble up or get very warm. Any
other worries at this point?
2) I will be using a small fish tank pump and bubbler rocks to
create a wide spread of bubbles. This will be my first time etching
with bubbles - I expect that this will speed up the etching process?
3) I also have a fish tank heater. I am not sure if I will use this
or not the first time around. However, I have read the comments " I
am using a hacked fish tank heater to warm the solution ". This
creates two questions for me.
3a) How hot do you need to make the solution?
3b) Do you really need to modify the heater to obtain the heat
desired or can you use it without modification?
4) I suspect if I use any form of metal clip to hang the circuit
board in the tank, it will probably corrode away and "waste" the
ferric chloride. So, I am thinking of hanging the circuit boards
with wire (insulated), is this a good idea?
5) based on the above descriptions ( and any modifications you folks
add), how long does etching take using this process? I don't want
to over etch, and trying to see though that brown solution isn't
very good. I will of course have to lift out the circuit board to
check it's progress, but if someone can provide an approximate time
that would be helpful in that I could detect if something is wrong.
TIA!
Chris
Re: [Homebrew_PCBs] Ferric Chloride etching questions...
2005-09-07 by Stefan Trethan
On Wed, 07 Sep 2005 15:57:41 +0200, lcdpublishing
seems about right. watch those stains!!
if you mix it fresh before your first etch you can use the heat in the
etchant i guess. Wasn't too dramatic.
yes, similar to mechanic agitation or brushing.
i remember something a small bit below 50C for ideal speed.
The fish would die, if there was no safety limit. many heaters can be
hacked by removing some sort of mechanical stop.
Please keep in mind ferric chloride is about as conductive as liquids get,
so take care with the electrics.
all but titanium will be etched, i think. You can use a plastic clamp, a
strip of sticky tape, a hole and some cord, .....
you must lift out the circuit board to check from time to time, it is in
the minutes range under good conditions up to hours under bad ones.
good luck, and i hope you bought the stain remover too, for any accidents
ST
Re: Ferric Chloride etching questions...
add
add
etching
process?
this
comments " I
be
liquids get,
clamp, a
folks
want
to
time
wrong.
is in
accidents
> ST
No, no stain remover, but I have plenty of old clothes that would
probably look better with a few stains :-)
Thanks Stefan, I hope to get some time today to do this but the day
is fading fast on me.
Chris
2005-09-07 by Phil
--- In Homebrew_PCBs@yahoogroups.com, "lcdpublishing"
> Okay,
nasty stuff. wear old clothes. mix in a large vessel as splashing
and sizzling can get pretty intense if you over do it. at this point
I suspect AP will sound pretty good :) There is a non-anhydrous form
of FeCl that people have mentioned that doesn't sizzle/splash/heat but
I've never seen it.
yes, speed up some but also make it more uniform. You'll get better
speed up by heating the etchant.
I use a Top Fin heater. I don't know if it's similar to yours but I
suspect they all come from the same chinese factory. There is a
mechanical stop that prevents much above 100F. You can leave it this
way and it will etch ok - about 12-15 minutes, typical. But, I like
my etchant at about 130F. I've heard of people going up to 160F but I
don't know how my plexiglass tank will take it.
You can remove the mechanical stop but there is a themo safety switch
(I don't know the correct name) that trips off at 110F. It takes
about 10 minutes to reset so I shorted it out (just twisted it) and
use a dimmer to control the temp. I'll someday build a real temp
controller for it.
enamel coated wire is great, I use it all the time.
some thoughts (many of which I'm sure you have figured out):
- keep your tank in a larger tub - there will be
splashes and FeCl makes a gawdawful mess.
- wear a rubberized apron (and your worst
old clothes)
- use rubberized gloves
- eye protection (the thought of a splash of FeCl
in the eye gives me the willys)
- make it easy to lift the board out with one hand
for inspection
Have fun and let us know your results
Phil
Re: [Homebrew_PCBs] Re: Ferric Chloride etching questions...
> I suspect AP will sound pretty good There is a non-anhydrous form
> I've never seen it.
I mixed it in a PET bottle (filled with cold water and added FeCl with a
funnel) and the heating wasn't bad. Splashing was not a problem in the
bottle. You can do it near a sink then you could put the bottle in a cold
water bath should it get too hot. The thing to remember is start out with
what the label suggests on water, no less. If you think you'll add some
water later you'll potentially have too much ferric chloride and not
enough water, and it could overheat.
As for eye protection, i found i much prefer a face shield over goggles.
Not so much of a difference with chemicals, as i never had an accident,
but when sawing etc. somehow the chips always find their way round the
goggles into my eyes. (Even have burnmarks on the EYE-SIDE of optical
glasses over which i wore ALLROUND CLOSED safety goggles when using the
angle grinder)
Dunno but those goggles do not seem to fit my face ;-)... hmmm maybe i
ought to try a diving mask!
Anyway, the face shield is much better protection and visibility, and it
was expensive so i make damn sure i avoid scratching it... wish they were
more popular here so i could get them replacement plastic sheets in the
shops.
ST
2005-09-07 by Adam Seychell
> Chris
I find diluted (1:0) hydrochloric acid removes ferric chloride stains in
minutes. Just apply a drop directly to the stain, then rinse.
Marketers have a habit of re-labeling and selling rudimentary products.
2005-09-08 by JanRwl@AOL.COM
In a message dated 9/7/2005 3:47:15 P.M. Central Daylight Time,
a_seychell@... writes:
Even quite diluted HCL will at least WEAKEN the fabric, no matter HOW
quickly you rinse! I would not do this on "good clothing"!
2005-09-08 by Phil
lol, if you are trying to remove an FeCl stain, it is no longer "good
clothing".
> a_seychell@y... writes:
stains in
2005-09-08 by Stefan Trethan
> clothing".
> stains in
Well, surely better than what i did!
I tried to get out a FeCl stain of a pair of jeans using some chlorine
(tablet) meant for pool water treatment.
Oh well, i still had the FeCl stain, but now i also had a much larger
bleached white area around it to highlight it ;-)
ST
