Fairlight-CMI
Index last updated: 2026-04-29 00:03 UTC
Fairlight III service in Europe
2012-04-24 by David
My Series III needs sorting out a bit. Won;t boot and the display card seems iffy (could be the cable!)
Anyway, is there someone near me who could check it out?
David
Belgium
Re: [Fairlight-CMI] Fairlight III service in Europe
2012-04-24 by Harald Feldmann
Hi David,
Maybe the two are related ? Have you tried re-seating the display card ?
Did you move the unit ?
Also, it it could be the cable, then there could be a short or a blown fuse.
I'm near Genk.
Not a technician though.
Harald.
> Thanks
> David
> Belgium
Re: Fairlight III service in Europe
2012-04-27 by horiprod
Hi David. A quick way I use to test mono graphics is to make up a 10-way IDC connector to RCA plug, and use this to plug into the AV video input of a television. Plug this lead into the Q-219 card, and you're bypassing all the CMI graphics leads and monitor. The connections are pin 7 hot, pin 8 cold. This also works for a IIX which uses the same graphics card.
Hope this is helpful,
Peter Wielk
Horizontal Productions in sunny Sydney
2012-04-27 by David
--- In Fairlight-CMI@yahoogroups.com, "horiprod" <horizontal_productions@...> wrote:
> Peter Wielk
Thanks Peter. Appreciate it.
If I find time, I'll have a go! I have a Series Iix so I guess I can trade graphic cards too. The main issue is that the III won't boot anyway
David
2012-04-27 by David
Hi Harald.
No, the Series III wouldn't boot before the graphics had problems.
I reseated all the cards previously but still no joy.
Thanks anyway
David
--- In Fairlight-CMI@yahoogroups.com, "Harald Feldmann" <feldmann@...> wrote:
> Hi David,
> I'm near Genk.
> Regards,
> Harald.
> > Thanks
> > David
> > Belgium
> > Yahoo! Groups Links
