Re: Buffered multiples?
2003-02-26 by ps_minor <pscottm@hotmail.com>
there was a discussion of this a while back.. apparently another solution is to feed a a180 mult w a a185 buss access module. the a185 is said to be robust enough to maintain accurate pitch voltage when its output is going to a mult and across several osc's. this may be simpler to impliment and take up less space. -psm --- In Doepfer_a100@yahoogroups.com, "Andreas Lindholm" < andreas.k.lindholm@t...> wrote:
> Works just fine for me, but you need that converter cable. > > > ----- Original Message ----- > From: <psm@w...> > To: <Doepfer_a100@yahoogroups.com> > Sent: Wednesday, February 26, 2003 9:54 AM > Subject: [Doepfer_a100] Re: Buffered multiples? > > > > Would that work in a standard Doepfer case? Thought there was > > something about the power supply? > > > > --- In Doepfer_a100@yahoogroups.com, "Andreas Lindholm" > > <andreas.k.lindholm@t...> wrote: > > > You can always get the buffered multiple from Analog Systems it is > > great. > > > > > > > > > > > To unsubscribe from this group, send an email to: > > doepfer_a100-unsubscribe@yahoogroups.com > > > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > > > >
