Doepfer
Buffered multiples?
Buffered multiples?
2003-02-26 by pstnotpd <psm@wanadoo.nl>
Hi guys,
Just pondering. I think I would appreciate something like a buffered
multiple for critical signal paths (A182?), i.e. cases when there is
a noticable voltage drift when using a normal multiple. It Would be a
nice addition to the standard multiples which suffice in most cases.
Does the inbuilt 'multiple' of the A175 inverter buffer?
Second: Has anybody had any succes in getting vowel sounds out of the
A127 using a MAQ? I'd imagine you would have trouble with the
inherent quantizing of the beast. Would a 5 octave range through a
VCA have enough resolution to get to the specific frequencies?
Cheers,
Patrick
Re: Buffered multiples?
Would that work in a standard Doepfer case? Thought there was
something about the power supply?
--- In Doepfer_a100@yahoogroups.com, "Andreas Lindholm"
<andreas.k.lindholm@t...> wrote:
> You can always get the buffered multiple from Analog Systems it is
great.
Re: [Doepfer_a100] Buffered multiples?
2003-02-26 by Andreas Lindholm
You can always get the buffered multiple from Analog Systems it is great.
To: <Doepfer_a100@yahoogroups.com>
Sent: Wednesday, February 26, 2003 8:00 AM
Subject: [Doepfer_a100] Buffered multiples?
> Hi guys,
> Cheers,
> Patrick
> doepfer_a100-unsubscribe@yahoogroups.com
2003-02-26 by Tim Stinchcombe <timothy@tstinchcombe.freeserve.co.uk>
No. The two sockets are simple connected together, so that you can
feed the signal to be inverted straight back out again.
Tim
2003-02-26 by Joe Buechler <buechlerjoe@toadmail.com>
a
What's wrong with the A185?
Re: [Doepfer_a100] Re: Buffered multiples?
Not much, but it doesn't span over many framecases so good, right?
Sent: Wednesday, February 26, 2003 7:56 PM
Subject: [Doepfer_a100] Re: Buffered multiples?
> a
