Doepfer
rs integrator moog filter and building extension cases
2003-01-28 by neilwight <neilwight@yahoo.co.uk>
hi there,
just joined the group and getting my first A100 this week.
it is the basic mini system with some extra loose modules.
how would i go about building an extra 3u case ontop of this to put
the extra modules in and build into.
do i just need a blank case and then put the buss board thats
available as an accessory in and join them together?
anyone in the UK know where to get cases from?
i also have an AS rs100 moog ladder filter unit. how easy will this
be to incorporate into the new rack. will it just plug straight in
or do i need some form of special cabling.
hope someone can shine some light on it all.
Re: rs integrator moog filter and building extension cases
2003-01-28 by ethanzer0 <ethanzer0@yahoo.com>
--- In Doepfer_a100@yahoogroups.com, "neilwight <neilwight@y...>"
The RS100 does use the same +/-12v
and +5v as the Doepfer modules.
However, AS modules use a 16pin
dipheader on a ribbon cable for
connecting to the RS powersupply.
If you want to mix and match AS and
Doepfer, the easiest way to go is to
buy an AS chassis/powersupply with
the Doepfer adapter.  Other wise, you
will have to fabricate a Doepfer to
AS adapter, which, BTW, I have done.
I will post a picture of it later
today so you can see what to do.
Ethan
ethan,
thanks, that would be great to see as i wouldnt mind manufacturing
one myself. i dont plan on getting too many AS modules just now so i
think i will stick with a doepfer case and the common bus etc.
do you make your own cases?
is it just a case of putting the extra bus board into a case and
then linking them up. i havent got the manual yet so maybe its all
laid out in there.
have you got an RS100? how do you think it compares to the a120 as
they are both moog copies.
neil
> Ethan
2003-01-28 by Tim Stinchcombe <timothy@tstinchcombe.freeserve.co.uk>
Hi Neil,
Coincidently I have just been wondering whether I could make up the
cases cheaper than buying them ready-made from EMIS. Conclusion - I
doubt it. Firstly with only about £20 difference between the G3 and
G6 cases, unless you need a small case, the G3 is not very economic.
Also, if you join the 'Doepfer Owners Club' that Andy Horrell of
EMIS 'runs', you get about 10% off all prices - if you get a thirst
for more modules (very likely to happen...!) you recoup the 'joining
fee' very quickly. So, the DOC price for a G6 is £175. You would need
1 PSU and 2 bus boards to put in it. These are £44 and £23 resp,
total £90. This doesn't include any panels yet, in particular the
back panel with the power receptacle and switch. Doepfer do actually
sell these as 'spares', at 35 euros, say £25. This leaves £60 for the
side, top and bottom panels, all the rails and threadstrips etc. Even
assuming you could find someone to sell them at half this £60 figure,
the hassle in a) trying to find a supplier, and b) having to screw it
all together (one would probably need to order all the screws
separately as well....), for my money, just isn't worth the other 30
quid!!
But don't let me put you off too much - it _is_ possible to put your
own cases together, and the Doepfer stuff is a 'standard' size (but
there are several 'standards'!), so if you want to build a custom
rack or just happen to come across something that will do, then go
for it.
Haven't got anything other than Doepfer stuff, so can't comment on
others, but don't forget that the A-108 filter is also a Moog ladder
type (which I do have, and sounds good!).
Tim
2003-01-29 by Joe Buechler <buechlerjoe@toadmail.com>
You only need a common bus if you're going to spread your VCOs and
ADSRs across cases. In a 6U or even 9U system it would be perfectly
feasable to keep these modules in one case on a single bus, to avoid
having to tie the buses together.
The cost of the 3U and 6U cases is mostly comprised of the power
supply, that's why the prices aren't that different. The actual 3U or
6U case and bus boards are sort of "thrown in" with the power
supply. Respects to Timothy, but neither is more "economical" than the
other, it all depends on how many power supplies you want or need, and
how you want to distribute the load among them.  I use two 3U cases
and a 6U case - it provides more flexibility in the configuration, and
the power-hungry modules can be allocated to the smaller cases to
reduce the load on each individual power supply.
It would be fun and probably satisfying to make your own case, but I
don't think there's be any economic advantage to it.
Joe
--- In Doepfer_a100@yahoogroups.com, "Tim Stinchcombe <timothy@t...>"
<timothy@t...> wrote:
> Hi Neil,
put
need
Even
figure,
it
> quid!!
> for it.
> Regards,
> Tim
2003-01-29 by ethanzer0 <ethanzer0@yahoo.com>
> ethan,
i
> laid out in there.
> neil
Hi Neil,
I uploaded two pictures in my folder
that depict the simple Doepfer to AS
power adapter I made for my suitcase
A100 when I added two RS95s. I have
since aquired a custom case for my
additional modules. I don't have an
RS100, though, I have heard folks
speaking highly of it. I do have an
A120 and I like it plenty.
this pic show the full construction.
The second pic shows the terminal
connectors I used. The power bus board
in my suite case just happens to have
terminals labled +12, -12, +5 and ground.
I used 4 color wire. The wire is connected
to the 16pin dip sockets the same way the
RS modules are labled. Just look at your
module. you'll see which is +12, -12, +5
or ground.
Let me know if you have questions,
Ethan
2003-01-29 by Tim Stinchcombe <timothy@tstinchcombe.freeserve.co.uk>
Hi Joe,
and
and
I agree entirely in that use of G3's or G6's depends on what you
want. However, if you just pile them one on top of the other as I do
(and plenty of others do too I suspect), then my current 3xG6 cases
as 6xG3 would cost an _extra_ £483 (or $783 at En-port prices).
That's _my_ economics ;-). So, each time you buy a G6 case you can
convince yourself that its the right thing to do - think of all the
money you have just saved, that can now be spent on other modules
instead. The downside is that with all that gaping, empty rack space,
you end up buying more modules sooner rather than later (so perhaps
it's not such good economics after all...).
BTW (for Neil, Richard and any others interested) I now notice that
on the Doepfer website under 'A100 Construction Details' not only is
there a link to the people whose stuff they use (ProMa), but also
a .pdf file of all the bits 'n bobs one needs to put a case together
oneself (right down to the captive nuts and self-tapping screws!)
Tim
space,
Hi Timothy
Apologies for the poor wording on my part. Yes I understand this point
of view, and I wouldn't see the point of having 6X G3 cases. Its
commonly said that the G3 case is uneconomical, I was just pointing
out that there's a different way of looking at it i.e. that you're
essentially buying power supplies, not cases. The G3 case isn't a
ripoff.
If I decide to add another row of modules, I can buy a G6 case, put
one of the G3 cases in storage, and have an A100 system with an odd
number of rows. I won't have a "gaping hole" that looks ugly and might
 make me spend a bunch of extra money for more modules than I
wanted - as you say, not good economics after all. Later, if I
decide to add yet another row of modules, I can add the second G3 case
back to the stack and create a system with an even number of rows
again.
What's more, the two G3 cases allow me to place the system bus (the G6
case) anywhere I want in the stack - top, middle, or bottom. This
flexibility turned out to be important to me, because I wanted the row
containing the A155 sequence on top (to be unencumbered by patch
cables), but I wanted the VCOs and ADSRs to me at eye level, rather
than on the bottom of the stack. So I have G3 on top, G6, and the
other G3 on the bottom. Works for me, anyway.
Joe
> Tim
2003-01-30 by neilwight <neilwight@yahoo.co.uk>
i had come to the same conclusion that the power supply was the
expensive part of the case.
i only have a system in a G3 at the moment but already have too many
modules.
i had though that perhaps i could have made up my own G3 case to go
ontop creating a G6 module for relatively cheap as the bus board is
only £30 and the power supply would be sufficient to cover them both.
i guess the smart thing would be to save up and buy a G6, move
everything into that and then fill it up then extend into the G3
when i grow bigger.
its just i have just gotten it and it is annoying that i will have
to spend my module money on a case.
oh well.
i guess thats how it goes :(
neil
2003-01-30 by Joe Buechler <buechlerjoe@toadmail.com>
Its possible to convert a G3 case to a G6 case easily and
inexpensively. Email Doepfer HW support for details.
OTOH if you got a G6 case you would have space for a 2-row and then
later a 3-row configuration, with any additional investment going
toward modules. Sometimes its a good feeling to have the PITA expenses
out of the way up front.
Joe
> modules.
both.
> when i grow bigger.
> oh well.
> neil
