info from doepfer about new CV EXPANDER MODULE/CHAOS MODULES AND MORE!!!
2003-01-13 by Bakis Sirros
dieter says:" > the planned CV expander module and the A-138 modules > are very similar. The difference is that the A-138 > are stand-alone modules that could be patched to any > other module to expand the number of CV or audio > inputs. The CV expander module has to be assigned > firmly to a module (e.g. A-121) and placed close to > the module as there are internal connections (not > via patch cables) between the modules. One will be > able do define via jumpers on the CV expander module > how the 5 inputs of the module are distributed to > the main module (e.g. A-121). E.g. one could use the > inputs 1-2 to expand the frequency control input of > the A-121 (to a total of 3), input 3 to expand the > resonance control input of the A-121 (to a total of > 2) and the inputs 4-5 to expand the audio input of > the A-121 (to a total of 3). In this examples 3 > internal connections between the CV expander module > and the A-121 will be necessary (CV frequency > common, CV resonance common, audio common). Usage of > the CV expander module will require a bit of > electronic knowledge and solder experience. We think > about adding a kind of "A-100 DIY corner" to our > A-100 web pages after the NAMM where some basic > principles of all A-100 modules are explained (e.g. > control voltage and audio summing with operational > amplifiers basic circuits, lin/log control, simple > modifications of existing modules - e.g. adding > CV/audio inputs/outputs, modifications of > A-150/A-151 for higher voltages and so on). > > b.t.w. In combination with the chaos/module of > uncertainty we are also working on a so-called > Chua-Oscillators (using negative resistors simulated > with NICs/negative impedance converters and > gyrators), Ueda attractors, Duffing oscillators, > chaotic FM (cross-coupled FM oscillators) and > others. But it's to early to publish details as we > are only in the beginning. Many of these functions > can be realized with existing modules but for some > functions new modules are required. More details > after the NAMM and if we have results we could > publish. > > b.t.w. We have now sound examples for the A-198 > available on our web site (made by our Italian A-100 > user Enrico Cosimi). > > This is my last message before I leave for the NAMM > tomorrow. > > (Feel free to publish all this information in the > group if desired) > > Best wishes > Dieter Doepfer > Doepfer Musikelektronik GmbH > http://www.doepfer.de > email: hardware@doepfer.de > > As we exhibit in January 2003 at the NAMM show in > Los Angeles/Anaheim (hall A / booth 6306) I will not > be able to answer emails from January 12 until 29, > 2003. Please address your technical questions to > technik@doepfer.de or software@doepfer.de during > this time. ANY COMMENTS? bakis. ===== synthfreak(parallel worlds) athens-greece [Doepfer_a100] group owner-moderator __________________________________________________ Do you Yahoo!? Yahoo! Mail Plus - Powerful. Affordable. Sign up now. http://mailplus.yahoo.com
