Doepfer
Re: It's sounds like there's nothing wrong with my VCA's!!
2003-01-11 by Tim Stinchcombe <timothy@tstinchcombe.freeserve.co.uk>
Hi Roel,
> Fascinating to hear that when you reach the highest position
> on the input of the 138 mixer, a small feedback resistor comes
> to action on the new models, compared to the older ones, which
> didn't amply!
I didn't manage to understand the set-up of your original problem
which led on to this discussion on the A-138 mixers. The ones I have
only attenuate, or at max settings give equal to what you put in,
i.e. all the resistors are the same so there is no amplification
possible. Thus I suspect what you experienced must be due to
something else. All my 138's are marked 'v2 1996', and from what I
know of the Doepfer strategy, I think it's unlikely there has been a
new design in the last 12 months since I last bought one. It's such a
simple circuit it's hard to say why it would have needed a revision
so quickly after they started making A-100's (one possibility might
be the inclusion of resistors to counteract the small voltage offsets
caused by the input currents of the op amps used). Maybe if someone
like Florian has a really early  one we could find out?
Tim
2003-01-11 by Roel Steverink
Date:  Fri Jan 10, 2003  10:01 am
Subject:  Re: [Doepfer_a100] It's sounds like there's nothing wrong with my
VCA's!!
Hi Florian,
Thanks for you explanation. I must say it's an complex picture.
I understand now that a lot of "perculiar" things that happen
when I patch a certain way, are unique to Doepfer and would
I use another brand, they could be totally different.
didn't amply!
When I understand the lin. versus exp. bit, and I extrapolate that
to the lin and exp. mixer, am I right to say that one type of mixer
is better to use for audio signals and the other for cv?
Roel.
Re: [Doepfer_a100] Re: It's sounds like there's nothing wrong with my VCA's!!
2003-01-13 by Florian Anwander
Hi Roel
> didn't amply!
This is a misunderstanding.
An signal transfering operational amplifier circuit _always_ uses
feedbackloop.
                  +-RRRR-<<-+
                  |         | <............This is the Feedbackloop.
sig.in >>--RRRR---+-| \     |
                    |   +>>-+-->>---Out
                Ground
          RRRR means Resistor
          >> shows the direction of the signal flow
As long as the both resistors have the same value there happens no
amplification. If the resistor in the feedbackloop has a larger value than
the input resistor, then the circuit will amplify the signal.
Lin / exp for the mixers only means, that the potentiometer have
logarithmic or linear characteristics. You simply can make on eout of the
other if you exchange the pots.
That is right.
Florian
