Doepfer
Re: It's sounds like there's nothing wrong with my VCA's!!
2003-01-11 by Roel Steverink
Date:  Fri Jan 10, 2003  8:12 am
Subject:  Re: It's sounds like there's nothing wrong with my VCA's!!
Hi Patrick,
I mark this: Linear VCA in the middle of signal path before a VCF. Thanks,
I'm gonna try this. To see what's the difference when I put the linear
in the middle or the exponential.
Thanks for your clear explanation!
Roel
Patrick wrote:
Also the linear VCA is primarily useable in the middle of the signal
path (for instance a VCA before a VCF) where linear control is
easier. For our ears an exponential volume curve is more natural
because of the way they work. Therefore an exponential VCA is usually
used at the end of the signal path.
Patrick
