Doepfer
Alesis Stealth Kick Pad and Pedal --> Doepfer A-100
2017-04-05 by Diego Ragnini
Hello,
hope everything is fine to everybody
Does anyone know if this kind of system might be used to trigger events on modular systems? It is designed to trigger drum machines and/or drum pad systems which provide proper trigger inputs… Just wonder if the signal should be “treated” somehow in order to be detected by trigger/gate inputs on Doepfer modules. The A-177-2 probably wouldn’t be enough for the purpose…
Best,
Diego
Re: [Doepfer_a100] Alesis Stealth Kick Pad and Pedal --> Doepfer A-100
2017-04-05 by John Hollis
Hi Diego,
Drum pads and the like use piezo transducers. You will need an amplifier with a high input impedance. Here is a link to a circuit for a trigger convertor:
http://www.paia.com/ProdArticles/drumsens.htm
Cheers,
John
> On 5 Apr 2017, at 05:16, Diego Ragnini diegora@free.fr [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> Hello,
> Best,
> Diego
And just checking the circuit, I would replace the 50K pot with 500K too suit a piezo.
> On 5 Apr 2017, at 07:55, John Hollis <john@hollis.co.uk> wrote:
> Hi Diego,
> Cheers,
> John
>> Hello,
>> Best,
>> Diego
The A-119 module should be good for this. It has a high gain input on a 1/4 jack, an adjustable gate and an envelope follower voltage for modulation.
Just tried a piezo with mine and it generates triggers.
Cheers,
John
> Hello,
> Best,
> Diego
Hi John, thanks a lot, then it should work plugging it into Mutable Instruments Veils or Ears, am I right? In any case I would ask the seller to let me try the patch before purchasing it...
Best, Diego
> Il giorno 05 apr 2017, alle ore 08:55, John Hollis john@hollis.co.uk [Doepfer_a100] <Doepfer_a100@yahoogroups.com> ha scritto:
> Hi Diego,
> http://www.paia.com/ProdArticles/drumsens.htm <http://www.paia.com/ProdArticles/drumsens.htm>
> Cheers,
> John
> > On 5 Apr 2017, at 05:16, Diego Ragnini diegora@free.fr <mailto:diegora@free.fr> [Doepfer_a100] <Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100@yahoogroups.com>> wrote:
> > Hello,
> > Best,
> > Diego
Cool I have got the A-119 as well! Thanks again, very precious support!
> Il giorno 05 apr 2017, alle ore 09:14, John Hollis john@hollis.co.uk [Doepfer_a100] <Doepfer_a100@yahoogroups.com> ha scritto:
> Cheers,
> John
> > Hello,
> > Best,
> > Diego
