> -----Ursprüngliche Nachricht-----
> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
> Gesendet: Montag, 5. September 2016 05:58
> An: Doepfer_a100@yahoogroups.com
> Betreff: Re: [Doepfer_a100] LC9 case problem
> You have to check this step by step, module by module:
> 1.) switch off the system, remove all modules, switch on again, and
> check whether on all busboards the +12 and -12 LEDs are lit.
> 2.) switch off the system, mount one module and connect it to the
> busboard, switch on again, and check whether on all busboards the +12
> 3.) continue with the next module like in step 2.
> 4.) continue with the next module like in step 2.
> 5.) ...
> You should mount the module in the most right position in a row as the
> last module. Otherwise you won't be able to see the LEDs.
> Florian
> On 04.09.16 21:28 , frzrscott@gmail.com [Doepfer_a100] wrote:
> > Hi, Hope someone can help here. I've just bought an LC9 case and am
> > experiencing trouble setting it up. All my modules are mounted correctly
> > with the red stripes matching the -12v... however, most of my modules
> > are unresponsive when switched on, i'm only getting a few lit LEDS on
> > two doepfer modules (a-113 and a148)... make noise DPO and intellijel
> > modules seem to get nothing at all.
> > Is there anything i could be doing wrong or did i receive a faulty case?
> > Thanks!
> Posted by: Florian Anwander <fanwander@mnet-online.de>
> Yahoo Groups Links
