Doepfer
Faulty A143-4 vclfo/vco?
2016-07-26 by jaccoville@yahoo.com
Hello Dieter,
While building my new drone station I discovered something odd.
With all new bought modules there is one which doesn't work properly, an A143-4.
Now I already own two of them so I compared them with the same (factory) settings, al jumpers in place except for the busCV jumper which I took out.
With all pots ccw and in LFO mode I slowly turn up the frequency on channel 1.
There is a big difference between the two modules, one will fully CW in a rather high speed, the other (faulty?) is probably only half that speed.
In VCO modus this is about the same, the good module goes really high (as it should) the other one stays at medium frequency.
The only way to get a really high frequency is by putting the common pot cw.
I tried al channels and checked all jumpers but I don't know what this problem is.
Please help.
Best regards
Jacco Ville
The Netherlands
Re: [Doepfer_a100] Faulty A143-4 vclfo/vco?
2016-07-27 by Florian Anwander
If there is an exception, then this is not a comparison.
Have them both setup really the same, then you may find significant results.
AW: [Doepfer_a100] Faulty A143-4 vclfo/vco?
2016-07-27 by yahoo@doepfer.de
Hello Jacco,
all A-143-4 should have a similar frequency range. Maybe the frequency
offsets were not adjusted as prescribed. There are four trimming
potentiometers on the A-143-4 pc board which are labelled "OFFSET 1" ...
"OFFSET 4". These are used to define the frequency offsets. You may try to
adjust the trimming potentiometers of the second module so that they match
to the other module.
Another reason could be a faulty heater. One of the integrated circuits is
equipped with a piggyback heater which warms up the circuit at about 40
degrees Celsius. If the heater is defective this may also cause a different
frequency range (and even the scale is probably off). Simply compare the
temperature of the heaters of the two modules about 10 minutes after power
on by means of touching them with the finger.
Pay also attention that the jumpers for the bus CV are the same for both
modules. Otherwise one of the modules may pick up a CV from the bus which
may cause different frequencies.
Hope this helps
Dieter Doepfer
> -----Ursprüngliche Nachricht-----
> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
> Gesendet: Dienstag, 26. Juli 2016 23:11
> An: Doepfer_a100@yahoogroups.com
> Betreff: [Doepfer_a100] Faulty A143-4 vclfo/vco?
> Hello Dieter,
> on channel 1.
> half that speed.
> common pot cw.
> this problem is.
> Please help.
> Best regards
> Jacco Ville
> The Netherlands
> Posted by: jaccoville@yahoo.com
> Yahoo Groups Links
2016-07-27 by Jacco Ville
Hello Florian,
My other two A143-4's are  also without the CVBus jumper , don't use the bussystem at all, and they work fine.
Comparison went 1:1.
Jacco
Verstuurd vanaf mijn iPhone SE Lunatik
> Op 27 jul. 2016 om 09:27 heeft Florian Anwander fanwander@mnet-online.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
Re: AW: [Doepfer_a100] Faulty A143-4 vclfo/vco?
Hello Dieter,
I double checked the jumpers and though I didn't measure I felt the piggybag heater was warm.
I contacted my supplier in Holland and he suggested to send it in.
Honestly....thank you very much for your reply but I don't want to "experiment" with a brand new module by touching the offsets and messing things up.
Because I am a bit unpatient I ordered a new one from Thomann.
Should be there tomorrow.
Hopefully it will work just as fine as the others. :-)
Thank you again
Best regards
Jacco Ville
The Netherlands
> Op 27 jul. 2016 om 09:50 heeft yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> Hello Jacco,
> Hope this helps
> Dieter Doepfer
>> Hello Dieter,
>> on channel 1.
>> half that speed.
>> common pot cw.
>> this problem is.
>> Please help.
>> Best regards
>> Jacco Ville
>> The Netherlands
>> Yahoo Groups Links
> Yahoo Groups Links
-----all A-143-4 should have a similar frequency range. Maybe the frequency
offsets were not adjusted as prescribed-----
Hello Dieter,
What is that prescription?
I mean, are these offset pots some kind of course regulation?
Do I have to use a frequencycounter?
Best regards
Jacco Ville
> Hello Jacco,
AW: AW: [Doepfer_a100] Faulty A143-4 vclfo/vco?
2016-07-28 by yahoo@doepfer.de
The instructions for the adjustment of the frequency offset is: about 32Hz
in VCO mode with all manual frequency controls at the front panel in center
position (no external CVs via sockets or bus).
Best wishes
Dieter Doepfer
> -----Ursprungliche Nachricht-----
> Gesendet: Mittwoch, 27. Juli 2016 14:22
> Betreff: Re: AW: [Doepfer_a100] Faulty A143-4 vclfo/vco?
> frequency
> Hello Dieter,
> Best regards
> Jacco Ville
> > Hello Jacco,
> Posted by: Jacco Ville <jaccoville@yahoo.com>
> Yahoo Groups Links
Re: AW: AW: [Doepfer_a100] Faulty A143-4 vclfo/vco?
2016-07-28 by Jacco Ville
Goodmorning Dieter,
Thank you, it's something I can work with.
Best regards,
Jacco Ville
> Op 28 jul. 2016 om 09:16 heeft yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> Best wishes
> Dieter Doepfer
> > frequency
> > Hello Dieter,
> > Best regards
> > Jacco Ville
> > > Hello Jacco,
> > Yahoo Groups Links
