Doepfer
A127 and the BOM
A127 and the BOM
2015-09-19 by achtung_999
Tomorrow I am picking up a used A127 from someone that sells it for a nice price.
I am of course looking at the BOM module also..
One HUGE question remains though:
why are the LFO outputs left off the BOM module?
Seems like a pretty strange omission to me...
Ernst
AW: [Doepfer_a100] A127 and the BOM
2015-09-21 by yahoo@doepfer.de
> Ernst
Of course the signals of the LFOs are available on the pc boards. But we would have to increase the width of the front panel to add
the LFO outputs. If you want to built your own breakout module I can tell you the corresponding solder points on the A-127 pcb.
Best wishes
Dieter Doepfer
Re: [Doepfer_a100] A127 and the BOM
2015-09-21 by achtung_999
Oh that would be excellent! Thanks!
Ernst
On Mon, Sep 21, 2015 at 10:59 AM, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> Ernst
Best wishes
Dieter Doepfer
Yahoo Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/Doepfer_a100/
<*> Your email settings:
Individual Email | Traditional
<*> To change settings online go to:
http://groups.yahoo.com/group/Doepfer_a100/join
(Yahoo! ID required)
Doepfer_a100-digest@yahoogroups.com
Doepfer_a100-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
Doepfer_a100-unsubscribe@yahoogroups.com
<*> Your use of Yahoo Groups is subject to:
https://info.yahoo.com/legal/us/yahoo/utos/terms/
btw. I have a version 2
On Mon, Sep 21, 2015 at 2:09 PM, achtung_999 <heinrich.himmelwasser@gmail.com> wrote:
Ernst
> Ernst
Best wishes
Dieter Doepfer
Yahoo Groups Links
2015-09-22 by achtung_999
Found this from a discussion in 2009:
"The LFO outputs are available at pin 7 (triangle) and pin 8 (rectangle) of
the TL084. 1k protection resistors should be used to connect these pins to
the additional sockets. And a simple voltage divider made of two resistors
is recommended for the rectangle output because pin 8 outputs about +/-11V
(i.e. ~ 22V overall voltage level).
Best wishes
Dieter Doepfer"
Is this also valid for the version 2?
And about the mentioned voltage divider: what values do you advise for these?
all the best,
Ernst
Ernst
> Ernst
Best wishes
Dieter Doepfer
Yahoo Groups Links
2015-09-22 by Nicholas Keller
http://www.raltron.com/cust/tools/voltage_divider.asp
Insert the input voltage of 22, value of R1 (numbers only, 1K = 1000), and desired output voltage of 5 (to match range of other Doepfer LFOs) or 10....and press compute.
On Tuesday, September 22, 2015, achtung_999 heinrich.himmelwasser@gmail.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
Best wishes
Dieter Doepfer"
all the best,
Ernst
Ernst
> Ernst
Best wishes
Dieter Doepfer
Yahoo Groups Links
Thanks for that Nicholas! Most helpful!
Ernst
On Tue, Sep 22, 2015 at 11:45 AM, Nicholas Keller maq163x2@gmail.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
Best wishes
Dieter Doepfer"
all the best,
Ernst
On Mon, Sep 21, 2015 at 2:09 PM, achtung_999 <heinrich.himmelwasser@gmail.com>; wrote:
Ernst
> Ernst
Best wishes
Dieter Doepfer
Yahoo Groups Links
RE: [Doepfer_a100] A127 and the BOM
2015-09-22 by Janne Gson Berg
Input voltage should be 11, not 22. +/- 11V should be transformed to +/- 5V.
/Janne
To: Doepfer_a100@yahoogroups.com
Date: Tue, 22 Sep 2015 12:19:03 +0200
Subject: Re: [Doepfer_a100] A127 and the BOM
Ernst
Best wishes
Dieter Doepfer"
all the best,
Ernst
On Mon, Sep 21, 2015 at 2:09 PM, achtung_999 <;heinrich.himmelwasser@gmail.com> wrote:
Ernst
> Ernst
Best wishes
Dieter Doepfer
Yahoo Groups Links
Yes! Thank you Janne!
On Tue, Sep 22, 2015 at 12:57 PM, Janne Gson Berg tapirkillen@hotmail.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
/Janne
Ernst
Best wishes
Dieter Doepfer";
all the best,
Ernst
Ernst
> Ernst
Best wishes
Dieter Doepfer
Yahoo Groups Links
2015-09-22 by yahoo@doepfer.de
> Best wishes
> Dieter Doepfer"
The circuitry around the LFO has not changed. So these notes are valid for all versions of the module.
The dimensioning of the voltage divider depends upon the desired attenuation of the rectangle signal. The load of the voltage
divider should be not less that ~ 5k. E.g. 3k+3k would half the level, 3k+1k would divide the level by 4. You may even use a 5k or
10k trimming potentiometer.
Best wishes
Dieter Doepfer
Great thanks Dieter!
Ernst
On Tue, Sep 22, 2015 at 1:48 PM, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> Best wishes
> Dieter Doepfer"
Best wishes
Dieter Doepfer
Yahoo Groups Links
My numbers were to reduce the LFO output to the typical Doepfer LFO range,
which is -/+2.5V, not -/+5V.
So 22->5 was correct for that result.
Nick
Ernst
> Best wishes
> Dieter Doepfer"
Best wishes
Dieter Doepfer
Yahoo Groups Links
