Doepfer
1200 mA Power supply
2015-09-05 by syndromeda@telenet.be
I know this is not the first time it comes in a topic but I'm really confused now. I used Modular Grid to finally see and check what was build together in my racks....well, very confusing it is, one my 3 HE racks is 870 mA +12V and 542 mA -12V plus 50 mA 5V, the other one is 920 mA +12V and 443 mA -12V, the third even is 970 mA +12V and 737 mA -12V !!! And the strangest thing is that everything seems to work normal....how is that possible, is the 1200mA power supply capable of much more, or can it handle large peaks?
Cheers,
Danny
Re: [Doepfer_a100] 1200 mA Power supply
2015-09-05 by achtung_999
It's 1200mA for the +12v and 1200mA for -voltage....
Do the maths..
On Sat, Sep 5, 2015 at 6:30 PM, syndromeda@telenet.be [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
Cheers,
Danny
That should explain a lot but this is not so obvious on the website:
12 V Power supply II
assembled and tested power supply +/-12V@ 1200mA with ring core transformer.
Danny Budts
info@syndromeda.be
www.syndromeda.be
https://www.facebook.com/Syndromeda
https://syndromeda.bandcamp.com/
https://www.facebook.com/pages/Syndromeda/189901007722025?ref=hl
----- Oorspronkelijk bericht -----
Van: achtung_999 heinrich.himmelwasser@gmail.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com>
Aan: Doepfer a100 <Doepfer_a100@yahoogroups.com>
Verzonden: Sat, 05 Sep 2015 20:30:28 +0200 (CEST)
Onderwerp: Re: [Doepfer_a100] 1200 mA Power supply
Do the maths..
> Hi,
> large peaks?
> Cheers,
> Danny
2015-09-05 by florian anwander
Hello
Am 05.09.2015 um 20:46 schrieb syndromeda@telenet.be [Doepfer_a100]:
That is how symmetrical power supplies are described usually. It is a
bit confusing for normal people. For technicians this is the normal naming.
Florian
Thanks Florian, and also thanks for letting me know that I belong to the normal people.... ;-)
Cheers,
Danny Budts
info@syndromeda.be
www.syndromeda.be
Van: florian anwander fanwander@mnet-online.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com>
Verzonden: Sat, 05 Sep 2015 21:15:38 +0200 (CEST)
Hello
Florian
AW: [Doepfer_a100] 1200 mA Power supply
2015-09-07 by yahoo@doepfer.de
> Hi,
> Cheers,
> Danny
The calculation of the currents is described in detail on the FAQ page of our website:
www.doepfer.com > FAQ > A-100 > Current specifications of A-100 modules and power supplies
We are about to specify the currents for +12V and -12V for each module separately (also it's not necessary when the A-100PSU2 or an
original A-100 case is used).
Best wishes
Dieter Doepfer
2015-09-07 by istari lasterfahrer
Hi
when each of your 3HE has its own power supply you should be fine, as each can run 1200mA on +12V as also on the -12V.
you do not add the +12V with the -12V to get the maximum current draw.
the calculation of the current draw should be done with maximum draw. so hopefully there will be no peaks above the calculation.
i have a case with a A-100PSU2 that draws aroun 1100mA from modules and runs ok. well it can get really hot in this case and i heared that maybe the power supply last not that long doing this...
some people say good practice is to have 1/3 or 1/4 headroom on the current consumtion.
regards
felix
Am 07.09.15 um 10:48 schrieb yahoo@doepfer.de [Doepfer_a100]:
Cheers,
Danny
Best wishes
Dieter Doepfer
Yahoo Groups Links
<*> To visit your group on the web, go to:
    http://groups.yahoo.com/group/Doepfer_a100/
<*> Your email settings:
    Individual Email | Traditional
<*> To change settings online go to:
    http://groups.yahoo.com/group/Doepfer_a100/join
    (Yahoo! ID required)
    Doepfer_a100-digest@yahoogroups.com
    Doepfer_a100-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
    Doepfer_a100-unsubscribe@yahoogroups.com
<*> Your use of Yahoo Groups is subject to:
    https://info.yahoo.com/legal/us/yahoo/utos/terms/
Sozialistischer Plattenbau Hamburg
Gaußstrasse 25 b
22765 Hamburg
Germany
http:sozialistischer-plattenbau.org
2015-09-07 by syndromeda@telenet.be
Thanks to anyone, now it's clear.
Cheers,
Danny Budts
info@syndromeda.be
www.syndromeda.be
Van: istari lasterfahrer istari@sozialistischer-plattenbau.org [Doepfer_a100] <Doepfer_a100@yahoogroups.com>
Verzonden: Mon, 07 Sep 2015 12:00:33 +0200 (CEST)
Hi
current consumtion.
regards
felix
>> Hi,
>> Cheers,
>> Danny
> Best wishes
> Dieter Doepfer
> Yahoo Groups Links
Gaußstrasse 25 b
22765 Hamburg
Germany
