> On 21 Jul 2015, at 11:33, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> > Hi Dieter,
> > What improvements or additions do you have planned for the A-111 update? I'd love to see CV controlled waveshaping if
> > that was possible?
> > Regards,
> > Neil
> It's far to early to speak about details. The idea is a triangle core with the precision of the A-111-1, analog tri-to-saw and
> tri-to-rectangle waveshapers and a voltage controlled DSP-based waveshaper. That way different waveshaping features will be
> possible. I'm not sure if we can make it still this year as there some other modules still in the holding pattern (also because of
> the firmware that has to be programmed/finished for A-157 and A-190-5).
> Best wishes
> Dieter Doepfer
