> On 13 Feb 2015, at 09:41, Florian Anwander fanwander@mnet-online.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> Hello Neil,
> The most "easy" way might be to use the linear cv inputs at the VCOs.
> Directly available at the A-111 or the forthcoming A-110-2. For the
> A-110(-1) you have to modify the module (see
> http://www.doepfer.de/a110_tec.htm <http://www.doepfer.de/a110_tec.htm>).
> Florian
> Am 13.02.2015 um 09:47 schrieb Neil Kagan blinkenlicht@yahoo.com <mailto:blinkenlicht@yahoo.com>
> [Doepfer_a100]:
> > I have a quick question. Using Doepfer modules, is there a way to get the MS-20 mini’s (Hz / Volt) output to scale correctly in order to control Doepfer oscillators? I had a Harvestman English Tear but it was a nightmare to set up properly. In my head this should be possible as it’s a question of scaling but whatever I try it doesn’t quite work.
> > Any help would be awesome :)
> > Neil
> > Posted by: Neil Kagan <blinkenlicht@yahoo.com <mailto:blinkenlicht@yahoo.com>>
> > Yahoo Groups Links
