Doepfer
A149-1 and A149-2 and S&H/T&H
2014-11-07 by David Kellett
A quick question - I'm not at home and wondering about a patch idea but can't experiment until Tuesday.
If I take a Gate from the A149-2 and feed it to both the Tigger and the Sample of a T&H circuit it will hold a high for the duration of the Gates high and then stay high until it gets another gate and then be immediately high again - is this correct? I'm thinking about using this with a sound with a long envelope on it (or just an envelope changing something in a self generating patch) to make a contrast with shorter acting random events. Will it work and with there be enough of a fall at the second gate to reset the envelope?
And also related - with the Dual S&H module how long will the Hold stay at its original level? I'm wondering about how long it will hold a pitch control voltage without wavering?
Hope this makes some sense - I would just wire it up and see if I was at home but having had the idea it is frustrating to not be able to have a go and see what happens!!
David
www.movingisliving.co.uk
