A-143-2 CV Bus
2014-10-29 by Neil Kagan
HI there, I’m wondering how easy it is to make the connections on my A-143-2 so it can pick up the gate signal from the bus? I’m not overly confident looking at the back of it and trying to recognise what needs connecting! Many thanks, Neil
2014-10-29 by yahoo@doepfer.de
> HI there, > > I’m wondering how easy it is to make the connections on my A-143-2 so it can pick up the gate signal from the bus? I’m > not overly confident looking at the back of it and trying to recognise what needs connecting! > > Many thanks, > > Neil The procedure is described on our website: www.doepfer.com > PRODUCTS > A-100 > DIY page > Subsequent bus normalling of modules Best wishes Dieter Doepfer
2014-10-29 by james.husted@mac.com
I have done this to a few of my Doepfer and a bunch of ones from other makers. It is easy to do on any modules that have normalizing jacks. All the Cliff style jacks used by Doepfer have normalizing contact but on many these are shorted to the pin they normalize to son some trace cutting may be needed. On some other makers modules, you may have to exchange jacks to ones with normalization. I have some AS modules and on those I was forced to make connections straight to the power bus not using the 16-pin ribbon, because they have power ribbon converters on them. I just wired to some standard 2-position jumper shunts and plugged them into the 2 pins on the power buss. I am surprised by how little this bus is used by makers. Almost every module that Synthwerks makes that produce a CV or a Gate can connect to this bus. I have an A-185 Bus Access module in every cabinet I have that has VCOs or EGs in them. -James James Husted, Designer, Synthwerks LLC • www.synthwerks.com • james@synthwerks.com • info@synthwerks.com
> On Oct 29, 2014, at 8:20 AM, Neil Kagan blinkenlicht@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: > > HI there, > > I’m wondering how easy it is to make the connections on my A-143-2 so it can pick up the gate signal from the bus? I’m not overly confident looking at the back of it and trying to recognise what needs connecting! > > Many thanks, > > Neil >
2014-10-30 by Neil Kagan
Thanks James, This will be my first venture into modding so you may well get another message at some point! Neil Sent from my iPhone
> On 29 Oct 2014, at 23:47, james.husted@mac.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: > > I have done this to a few of my Doepfer and a bunch of ones from other makers. It is easy to do on any modules that have normalizing jacks. All the Cliff style jacks used by Doepfer have normalizing contact but on many these are shorted to the pin they normalize to son some trace cutting may be needed. On some other makers modules, you may have to exchange jacks to ones with normalization. I have some AS modules and on those I was forced to make connections straight to the power bus not using the 16-pin ribbon, because they have power ribbon converters on them. I just wired to some standard 2-position jumper shunts and plugged them into the 2 pins on the power buss. > > I am surprised by how little this bus is used by makers. Almost every module that Synthwerks makes that produce a CV or a Gate can connect to this bus. I have an A-185 Bus Access module in every cabinet I have that has VCOs or EGs in them. > -James > James Husted, Designer, Synthwerks LLC • www.synthwerks.com • james@synthwerks.com • info@synthwerks.com > > > On Oct 29, 2014, at 8:20 AM, Neil Kagan blinkenlicht@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: > > > > HI there, > > > > I’m wondering how easy it is to make the connections on my A-143-2 so it can pick up the gate signal from the bus? I’m not overly confident looking at the back of it and trying to recognise what needs connecting! > > > > Many thanks, > > > > Neil > > > >
