Doepfer
MAQ 16/3 sync problem
2014-06-05 by JenkinsC01@aol.com
I have two MAQ 16/3s. One will sync fine to a MIDI clock from Cubase SE3. The other refuses to do so - it will start, but won't keep steady time. I've tried switching cables. mergers and so on, but it does seem to be a problem with the MAQ itself. Its firmware is V3.50, while the one that works fine is V3.70.
Is there any way to do a 'system reset' to see if this sorts itself out? Or should I get a firmware update done, or does this sound like a fault requiring repair?
Re: MAQ 16/3 sync problem
Problem solved...
...it was the external power supply. I swapped it for a beefier one, and as if by magic, the MIDI sync works - plus as a bonus, the LED is brighter! Not surprising that an under-par power supply should affect the sync, but everything else worked fine with it - and it was the supply I got with the MAQ, and was theoretically in spec. It just goes to show, er, something...
Re: [Doepfer_a100] Re: MAQ 16/3 sync problem
2014-06-06 by christian ienni
"MOAR POWAR!!!"
On Thursday, June 5, 2014 12:28 PM, "JenkinsC01@aol.com [Doepfer_a100]" <Doepfer_a100@yahoogroups.com> wrote:
Problem solved...
AW: [Doepfer_a100] MAQ 16/3 sync problem
2014-06-10 by yahoo@doepfer.de
Please contact Christian Assall (software@doepfer.de). He programmed the
MAQ16/3 firmware and knows if an upgrade may solve the problem.
Best wishes
Dieter Doepfer
