Doepfer
Re: Clocking the modular from Ableton Live with A-190-8
2014-06-04 by matthias.ochs@gmx.de
> Try removing the hub and go straight to the A-190. Hubs are sometimes problematic and can lead to
> unexpected behavior in many different scenarios.
Yes, when I was writing my first post that occured to me to. I'll try it. Also gonna try with a MacBook...
Re: [Doepfer_a100] Clocking the modular from Ableton Live with A-190-8
2014-06-04 by james.husted@mac.com
Another thing to check when using clock dividers is that some are what I call "mathematical" dividers and some are "musical" ones. I don't know which the Pamila's is. A Musical one produces clocks on the downbeat where as the math versions go on the number of clocks. Since I can't attach a graphic I will try and explain it this way:
If you are looking at the divide by four out of a Math version, the out will be like this:
0ne-two-three-FOUR-one-two-three-FOUR-one-two...etc.
on a musical one it would be:
ONE-two-three-four-ONE-two-three-four-ONE-two...etc.
When you reset a Math one all the outs go LOW, when you reset a Musical one, all the puts go HIGH. This makes a lot of difference when clocking rhythms against each other. A Math one will always seem off.
-James
James Husted, Designer, Synthwerks LLC • www.synthwerks.com • ;james@synthwerks.cominfo@synthwerks.com
On Jun 4, 2014, at 6:15 AM, matthias.ochs@gmx.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
AW: [Doepfer_a100] Clocking the modular from Ableton Live with A-190-8
2014-06-05 by yahoo@doepfer.de
> -James
Some customers mentioned that such a "musical" clock divider would be
helpful. We have the prototype of a new clock divider A-160-2 available
which has two three-position toggle switches available that allows to select
one of nine different operating modes. Apart from that it's very similar to
the existing A-160: two inputs (planned for clock and reset) and 7 outputs
with LEDs. Currently we are about to find out which would be the best nine
modes.
Here is the link to the (hidden) front panel picture:
www.doepfer.de/A160_2.gif. The labelling of the switches is just an example.
The hardware of the module is already finished. It will be available as soon
as the nine modes are defined and the corresponding firmware is programmed
(probably late summer/fall 2014).
Best wishes
Dieter Doepfer
> just an example.
> I fear it's a bit *too* well hidden... that redirects to a
> picture of the A-190-2, which is far less secret. :)
Sorry - I forgot to copy the picture to our webspace. Now it's online.
Dieter
2014-06-05 by achtung_999
Finally uneven divisions! Thanks Dieter!
Any idea when this will be released?
Ernst
On Thu, Jun 5, 2014 at 11:08 AM, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> just an example.
Dieter
Yahoo Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/Doepfer_a100/
<*> Your email settings:
Individual Email | Traditional
<*> To change settings online go to:
http://groups.yahoo.com/group/Doepfer_a100/join
(Yahoo! ID required)
Doepfer_a100-digest@yahoogroups.com
Doepfer_a100-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
Doepfer_a100-unsubscribe@yahoogroups.com
<*> Your use of Yahoo Groups is subject to:
https://info.yahoo.com/legal/us/yahoo/utos/terms/
Arrgh sorry about that just see that you mentioned that already...
On Thu, Jun 5, 2014 at 12:49 PM, achtung_999 <heinrich.himmelwasser@gmail.com> wrote:
Ernst
> just an example.
Dieter
Yahoo Groups Links
And a little comment because you mentioned the software isn't done yet:
Devision by 9 would be a nice one to include i.m.o.
Ernst
On Thu, Jun 5, 2014 at 12:50 PM, achtung_999 <heinrich.himmelwasser@gmail.com> wrote:
Ernst
> just an example.
Dieter
Yahoo Groups Links
