Doepfer
A-183-2 Problem
A-183-2 Problem
2014-01-22 by David.Woof@gmail.com
(Apologies if this has double posted, but my first one didm;t seem to appear).
On the web-page for this module...
http://www.doepfer.de/a1832.htm
...it states:
"The amplification range for the input is about 0...+2 in the attenuator mode, and -2...+2 in the polarizer mode, i.e. the maximum amplification will be x2 and the module can be used also to amplify CV or audio signals (for other amplifications only the value of a resistor has to be changed). Consequently the term Attenuator is not fully correct as the input signal can be also amplified a bit."
I've got two of these, and neither provides this x2 gain on the inputs, irrespective of the jumper setting. Is this correct behaviour, or is the web-page wrong?
Thanks!
