Doepfer
a-190-1 last note priority?
2013-12-10 by t.o.t.s.
Is the anyway to set the a-190-1 to have a last note priority function so i can say, hold down one note, trill others and have the last note that is still be held sound? the current a-190 behavior is to shut notes off regardless of any keys been held down once the most recent key is released. just trying to get it to behave like classic monosynth behavior. If the a-190-1 can't do this, can you recommend a module that can?
Thanks!
Re: [Doepfer_a100] a-190-1 last note priority?
2013-12-10 by Florian Anwander
Hello
This is not last note priority. This works only with lowest or highest
note priority - and you have to say which kind of trill you want to
play, before you can select the priority (hold the lower note -> highest
prio; hold the upper note -> lowest prio).
Florian
And a short Addition...
you need a retrigger mode for that. I am not sure, whether the A-190 has
one.
Florian
