ms404 scale
2013-11-10 by aletropdj@yahoo.com
2013-11-10 by Nicholas Keller
That may just be the way it is. Other synths, sequencers, and convertors have a similar offset, which you can compensate for with the tune knob on whatever synth or VCO you at controlling. The important thing is that the scale is 1V/Oct, which .3, 1.3, 2.3... is. Nick Sent from the future
> On Nov 10, 2013, at 2:22 PM, <aletropdj@yahoo.com> wrote: > > Hi all, > > > When I got my ms404 a few years ago I knew that was not calibrated, and today I got some time. > Because I couldn't calibrate, I found P2 pot was lose. It was desoldered and after fixing I could set the CV scale. > But in the end the cv out its 0.3v, 1.3v, 2.3v, etc... > > any tip? > >
2013-11-11 by aletropdj@yahoo.com
hum...ok. so its good :)
Do you know what is for P17 trimmer? it says scale, but apparently its not doing anything...
On Nov 10, 2013, at 2:22 PM, <aletropdj@...> wrote:
Hi all,
When I got my ms404 a few years ago I knew that was not calibrated, and today I got some time.Because I couldn't calibrate, I found P2 pot was lose. It was desoldered and after fixing I could set the CV scale.But in the end the cv out its 0.3v, 1.3v, 2.3v, etc...any tip?
2013-11-11 by yahoo@doepfer.de
That's normal. The DAC used in the MS-404 had about 250...350mV offset. But after all it does not matter as the absolute tuning can be adjusted by a trimpot and the front panel control Best wishes Dieter Doepfer
> -----Ursprüngliche Nachricht----- > Von: Doepfer_a100@yahoogroups.com > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von aletropdj@yahoo.com > Gesendet: Sonntag, 10. November 2013 20:22 > An: Doepfer_a100@yahoogroups.com > Betreff: [Doepfer_a100] ms404 scale > > Hi all, > > When I got my ms404 a few years ago I knew that was not > calibrated, and today I got some time. > Because I couldn't calibrate, I found P2 pot was lose. It was > desoldered and after fixing I could set the CV scale. > But in the end the cv out its 0.3v, 1.3v, 2.3v, etc... > > > any tip?
