Doepfer
A-100 Suitcase Base A-100PB
2013-10-21 by Os
Just became aware of the new case announcement.
Looks very useful! I appreciate that the front section is nice and deep.
I would like to know though how long a power cable is required for the
modules in the front, given that the bus board is at the back.
cheers,
os.
http://www.doepfer.de/home_e.htm
Probably from December 2013 the "small brother" of the monster base
A-100PMB will be available. The new case A-100PB is very similar to
the A-100PMB but has only half the width (2 x 84 HP for installation
of modules). The suitcase versions A-100P6 or A-100P9 can be
positioned on top of the A-100PB because the width of the A-100PB is a
bit more than the width of A-100P6/P9 and the footprint of the A-100PB
is adapted to the depth of A-100P6/P9. A-100PB is equipped with one
power supply (1200mA) and two bus boards. The bus boards are located
in the rear area (even those for the modules that are mounted in the
front row). This was necessary to take advantage of the full height of
the front area for installation of A-100 modules. The max. depth for
modules in the front row is ~70 mm.
The price of the A-100PB will be about Euro 550 (without modules).
os@collective.co.uk
http://twitter.com/expertsleepers
http://www.darkroomtheband.net/
http://www.expert-sleepers.co.uk/
AW: [Doepfer_a100] A-100 Suitcase Base A-100PB
2013-10-21 by yahoo@doepfer.de
> cheers,
> os.
20 cm is still sufficient as the bus board is close to the modules in the
front row (just behind the area required for the modules, same bus board
position as for A-100PMB or A-100LCB).
Best wishes
Dieter Doepfer
