Doepfer
Proper fuse for old A100 System
2013-08-26 by David
Hello,
I have an old 19" A100 system, made before 2002, that has blown it's fuse - 250v 100mA T (slow blow). The power supply is a Hahn BV UI 394 0088, 2x115v 600mA.
Should I replace it with the same fuse, or something else - like 250v 250mA T?
Thanks for the advice,
David
AW: [Doepfer_a100] Proper fuse for old A100 System
2013-08-27 by yahoo@doepfer.de
> Hello,
> 250v 250mA T?
> David
The fuse values depend upon the mains voltage which I cannot see from your
message. You find a list of the fuse values for all A-100 cases on our
website:
www.doepfer.com > FAQ > A-100 >  values for A-100 fuses
Best wishes
Dieter Doepfer
