Hello
In general: I cannot speak for Dieter, but I assume, he is adding these
extensions to the schematics as suggestions for diyers with at least a
little knowledge. If I was him, I would keep it that vague, so noone can
complain about "works not like expected" as he does not set any expectation.
Am 25.06.2013 10:39, schrieb Neal Layton:
> Am I reading this correctly?
Yes
> If so what is their function and values?
The function is attenuation.
As value you may take 50k lin, but other values (10k <-> 500k) will be
ok. Also whether you are using lin or log is more a matter of taste,
than a technical necessity.
Florian
