> -----Ursprüngliche Nachricht-----
> Von: Doepfer_a100@yahoogroups.com
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von the_real_dripfeed
> Gesendet: Montag, 23. Januar 2012 13:33
> An: Doepfer_a100@yahoogroups.com
> Betreff: [Doepfer_a100] A very small suggestion for Dieter (regarding
> A-100BC cable)
> Hi Dieter
> Perhaps you could make the CV/GATE extension cable (A-100BC) a
> little longer?
> I built my 6U from your excellent DIY kit and eventually bought
> an A-100BC to extend CV and GATE to the 2nd busboard. But I had
> mounted my two busboards far enough apart in my case that the
> A-100BC cable was about 3 cm too short.
> I extended the A-100BC by soldering in an extension, so all is
> well. But I thought that the A-100BC could be maybe 50% longer
> for chumps like me who build their own cases ;-)
> Thanks for a great system by the way...loving your new quad VCLFO.
The length of the A-100BC cable adapted to distance between the bus boards
our cases (A-100G6/P6/P9/LC6/LC9 ...). Usually the distance between the bus
boards is in the same range as the front panel height (i.e. about 13 cm). We
assumed that ~20 cm length should be long enough (that the usual lengt for
the A-100BC).
Best wishes
Dieter Doepfer
