Doepfer
A190-1 won't turn on
2011-10-23 by guptaudbhav
I was moving some modules in my case and adding a couple of new ones.  After doing so, i turned on the case, and the MIDI cv convertor won't come on, the gate lights don't flash, it seems completely dead.  Checked the cable with another module, works fine, so I feel like I did something to fry it.  Anything I can do to troubleshoot or things I should check?
Dev
Re: A190-1 won't turn on
2011-10-23 by NetPierre
Hi Dev,
Not sure, but have you checked if the extra +5Volt power supply, needed for the A-190-1 is correctly installed / in the same rail as your A-190 Module?
Good luck,
Pierre Serné / PatchPierre
http://patchpierre.blogspot.com/
--- In Doepfer_a100@yahoogroups.com, "guptaudbhav" <gupta.udbhav@...> wrote:
> Hi,
> Thanks,
> Dev
Ahhh Pierre you're a lifesaver, I'm such a dummy.  I totally forgot that the bottom rail on my case doesn't have the extra +5v.  Thank you so much.
Dev
--- In Doepfer_a100@yahoogroups.com, "NetPierre" <pierre@...> wrote:
> Hi Dev,
> Good luck,
> --- In Doepfer_a100@yahoogroups.com, "guptaudbhav" <gupta.udbhav@> wrote:
> > Hi,
> > Thanks,
> > Dev
