Doepfer
Re: A-192 CV-MIDI Converter Q's
2011-09-16 by kurvenschreiber
> Wouldn't an A-183-2 be better for this? 4hp and at 1/3x the price?
Thanks for the reply !
Yep, but it's only one channel, think it very useful to have more(2 channels of SQ-10, LFO's from -2.5 to +2.5, inverted envelopes etc) ...
2011-09-16 by Richard Horsman
>My question is about using A-192 CV-MIDI converter.
>I need  to get -5 to +5 V data from KORG MS's in MIDI cc's
>But input of A-192 is only from 0 to +5V.
>I've e-mailed to Dieter with this question, and have advice to
>use Vocoder-Attenuator-Offseter A-129-3 to solve this problem.
>But also Dieter has advised to set  this question here,
>to get more information about communication different voltages devices...
A-190 broken?
2011-09-16 by bruce thedekaa
Hi list.
Last night i've put an Metasonix R-51 in my rack.Unfortunately the red wire on my Metasonix cable needed to be on top instead of on the bottom. So when i inserted the cable, red down, and turned my set on, the fuse blew.Just replaced the fuse and when i turn my rack on all led's on my A190 turn on.Did a hard RESET (all four buttons).Put the module in another rack.Nothing helps, anybody had the same problem or knows an solution?
Greets bRz
Re: [Doepfer_a100] A-190 broken?
2011-09-16 by Rudy Toussaint
Maybe check your 5 volt adaptor which I think is needed for the a-190
Envoyé de mon iPhone
A-190
Le 2011-09-16 à 11:18, bruce thedekaa <brztdk@yahoo.com> a écrit :
> Hi list.
> Greets bRz
Thanks for the reply.
I already checked this. I also dubbel checked it in another rack, which has another 5V adaptor.Any other ideas?
grtz
--- On Fri, 9/16/11, Rudy Toussaint <rudetee@yahoo.com> wrote:
Subject: Re: [Doepfer_a100] A-190 broken?
To: "Doepfer_a100@yahoogroups.com" <Doepfer_a100@yahoogroups.com>
Date: Friday, September 16, 2011, 6:47 PM
A-190
> Hi list.
> Greets bRz
AW: [Doepfer_a100] A-190 broken?
2011-09-19 by yahoo@doepfer.de
> Hi,
> grtz
Probably the +5V and +12V have been shortened when the other module hes been installed. This would fry the +5V circuits of the A-190. Please contact out A-190-1 specialist Matthias Marass (keyboards.at.doepfer.dot.de). He is responsible for the A-190-1 service.
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] A-190 broken?
2011-09-20 by bruce thedekaa
Hello,
Thanks for the advice, just send him a mail.
Greets bRz
--- On Mon, 9/19/11, yahoo@doepfer.de <yahoo@doepfer.de> wrote:
Subject: AW: [Doepfer_a100] A-190 broken?
To: Doepfer_a100@yahoogroups.com
Date: Monday, September 19, 2011, 11:12 AM
      > Hi,
> grtz
Best wishes
Dieter Doepfer
