Doepfer
Re: [Doepfer_a100] Re: A-195-1 Pitch-to-CV/Midi/USB
2011-04-29 by Tony Steventon
Hi Jon,
I still use the A119 as well since the 35 doesn't do it all. I guess the 35 is ok but I have not tried to compare it with other pitch converters and for an anologue solution I thinks it's good  but sometimes finnicky as the input needs to be 'unconfused' shall I say. Tracking seems ok; I will do a more scientific test when I get the chance and maybe pop it onto YouTube.
Bob williams sent me a huge patch that uses a VCF as a tracking filter for rhe 35 but I have not tried that yet. I think Bob has had lots of issues with blown up modules due to the divergent standards and technically 'variable' users (and why should a user have to be an electronics expert?) hence the warranty conditions. Sorry I was being a bit smug anyway as I have a decent adaptor which while not foolproof is easier to understand and use than some of the cable adaptors I've seen.
Cheers
Tony
On 29 Apr 2011, at 22:48, "codotinc" <doubleopards@hotmail.com> wrote:
Hi Tony,
Mostly I was just being snarky there, but I know over on Muffwiggler there have been many complaints about fried ASys modules in Doepfer racks, a complaint which I've not seen applied as often to any other manufacturer. Also, there's the caveat that using ASys modules with any other manufacturers' cases/power supplies voids the warranty.
I also don't like that the RS35 can not be used to input external audio for the purpose of further audio processing (no audio output); that it can ONLY be converted to CV. Seems like an easy bit of additional flexibility.
However, I don't know of any other Eurorack Pitch-CV converters; how does the tracking on the RS35?
Cheers,
Jon
--- In Doepfer_a100@yahoogroups.com, Tony Steventon <tony.steventon@...> wrote:
> My RS35 has never exploded my Doepfer rack - why the fear? I have multiple manufacturer's modules in mine and they are all work well together. Still I'd welcome any new modules from Doepfer.
> Cheers
> Tony
> Sent from my iPhone
> On 29 Apr 2011, at 21:46, "codotinc" <doubleopards@...> wrote:
> Hi Doepfer-ers and Dieter,
> Hoping that the A-195-1 will actually make it to production sometime. Really do not want to use the ASys RS-35, as any module with the likelihood of exploding my lovely Doepfer system is not welcome in my A-100P6.
> As it is still in the planning stage I would also like to suggest that it could perhaps have the option to use it simply as a external input pre-amp, without the conversion (maybe a second, 'dry audio' output?), and integrate slew and envelope follower as well.
> Regarding the artifacts which may occur during the "attack" and "release" states: from my experience using the Pigtronix Mothership guitar synth as well as other guitar synths, there are *always* artifacts during these states when using a guitar, though these are lessened when using compression. However, a compressor also squares off the envelope greatly, which makes it less like a guitar envelope. But my suggestion is that a Pitch-CV converter will likely always be imprecise, and that's OK by me.
> Cheers, thanks for the great work.
