Doepfer
how many stages
how many stages
2010-12-26 by martindx100
hmm
how many stages does the A-125 phase shifter have?
and how wide is the bandwidth (at +/-1dB)?
i´m probably the only one that asks these questions :)
/martin
Re: [Doepfer_a100] how many stages
2010-12-26 by Bakis Sirros
IIRC, its 6 stages.
Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. vu-us. com
--- On Sun, 12/26/10, martindx100 <martin@teknofon.com> wrote:
Subject: [Doepfer_a100] how many stages
To: Doepfer_a100@yahoogroups.com
Date: Sunday, December 26, 2010, 11:09 PM
      hmm
/martin
2010-12-27 by Florian Anwander
Hello Martin
A phaser has a bandwith of maybe 100 cent within +/-1dB due to its basic
principle of suppressing certain frequencies...
Florian
2010-12-27 by martin sörensen
i was hoping for a wider bandwith
with less phase-distortion
something like figure 5 in this article
http://webpages.charter.net/wa1sov/technical/allpass/allpass.html
/martin
  Sent: Monday, December 27, 2010 9:47 AM
  Subject: Re: [Doepfer_a100] how many stages
  Hello Martin
  Florian
Hi Martin
either me do not understand what you are asking for, or you do not
understand that the basic principle of an allpass filter IS the phase
shift. It is the reason why someone is building an allpass filter.
Or do you mean "phase distortion" as: deviation of the "real (measured)
phase shift over frequency" from "the ideal phase shift over frequency"?
If the latter is the case: I fear there is no voltage controlled allpass
filter that suits your (a littlebit academic) requirement. Simply
because you will not be able to trim 12 variable stages to exactly the
identical characteristics. You should also obey, that the page you are
quoting speaks about a static phaseshifter!
 From the musical and sound-engineering approach, this kind of
phasedistortion is irrelevant.
Florian
> /martin
2010-12-28 by martin sörensen
hi
yes it's a littlebit academic :)
i'm using my doepfer in combination with a argon-krypton laser to make visuals :)
the thing i'm looking for is a static wide band 90° phase shifter (90° shift from 40Hz-1kHz)
/martin
  Sent: Monday, December 27, 2010 11:48 AM
  Hi Martin
  Florian
  > /martin
2010-12-29 by Florian Anwander
Hi Martin
ok, then all classic audio phasers are not usable for you. Because the
OTAs have a too wide variance. If you do not need voltage control
anyway, then build the circuit as described in your link.
May be there are other circuits to achive a static phase shift over a
wide frequency range. But I do not know them.
Florian
Analogue Systems modules in a A-100 and warranties.
2010-12-29 by Andrew Capon
Hi Guys,
I hope you all had a good Christmas.
I have recently started building a small modular in a 9U A-100 suitcase.
I would like to add a Analogue Systems RS35 module.
On the Analogue Systems web site it states that if you add one of their modules to a doepfer system it will void both the warranty of the module and the rack.
Looking at the warranty info on the Doepfer site I cannot see anything about this, apart from the worrying line "Any repair or opening of the unit carried out by unauthorized personnel (including the user) will void the warranty." which cannot be valid for modular systems surely?
So I just wondered should I worry about adding this module or just go for it?
Thanks for any help
Andy
Re: [Doepfer_a100] Analogue Systems modules in a A-100 and warranties.
2010-12-29 by Bakis Sirros
hi Andrew,
you can of course mount AS modules into a doepfer case, but watch out, because you need a special converter ribbon power cable in order to put an AS module into a doepfer case.
you can buy this cable from the AS website, or from analogue haven (US) and probably from many other modular outlets.
also, some AS modules (mostly the digital ones) need +5 volts supply that the doepfer case does not supply by default.
thanks,
Bakis.
www. DiN. org. uk
www. vu-us. com
--- On Wed, 12/29/10, Andrew Capon <andrew.capon@zen.co.uk> wrote:
Subject: [Doepfer_a100] Analogue Systems modules in a A-100 and warranties.
Date: Wednesday, December 29, 2010, 12:03 PM
      Hi Guys,
Thanks for any help
Andy
Hi Bakis,
Thanks very much for the info.
As have the module and the cable in stock so I am ordering one, I will let you know how it goes.
I will check the RS35 doesn't need 5V as well, my guess is that I will be ok.
All the best
Andy
On 29 Dec 2010, at 10:55, Bakis Sirros wrote:
> hi Andrew,
> thanks,
> Bakis.
> www. DiN. org. uk
> www. vu-us. com
> From: Andrew Capon <andrew.capon@zen.co.uk>
> Hi Guys,
> Thanks for any help
> Andy
plus, there will be a small aesthetic issue: there will be an 1HP gap between Doepfer modules and the ASystems modules.
Doepfer sells an 1HP blank plate to fill this gap.
www. DiN. org. uk
www. vu-us. com
Subject: Re: [Doepfer_a100] Analogue Systems modules in a A-100 and warranties.
Date: Wednesday, December 29, 2010, 12:59 PM
Hi Bakis,
All the best
Andy
> hi Andrew,
> thanks,
> Bakis.
> www. DiN. org. uk
> www. vu-us. com
> Hi Guys,
> Thanks for any help
> Andy
Yahoo! Groups Links
2010-12-29 by James Husted
Actually it is a 1/2 a HP - doepfer sells the 1.5HP panels for that.
Andrew - it is because Doepfer has their holes .3" form the edge of the metal and AS has theirs .2" from the edge. and a HP is .2" - The hole to hole spacing on the panels themselves is fine though.
-James
> www. DiN. org. uk
> www. vu-us. com
> Hi Bakis,
> All the best
> Andy
>> hi Andrew,
>> thanks,
>> Bakis.
>> www. DiN. org. uk
>> www. vu-us. com
>> Hi Guys,
>> Thanks for any help
>> Andy
Hi James and Bakis,
Thanks for the info, I have some 2HP panels but not any 1.5HP.
I can live with a small gap though.
Its all ordered now. I'm looking forward to plugging a guitar into it.
All the best
Andy
> -James
> > www. DiN. org. uk
> > www. vu-us. com
> > Hi Bakis,
> > All the best
> > Andy
> >> hi Andrew,
> >> thanks,
> >> Bakis.
> >> www. DiN. org. uk
> >> www. vu-us. com
> >> Hi Guys,
> >> Thanks for any help
> >> Andy
> > Yahoo! Groups Links
> > Yahoo! Groups Links
2010-12-30 by Bakis Sirros
yes, indeed, sorry.
i never had to get such a panel that's the reason that i could not remember the exact width.
www. DiN. org. uk
www. vu-us. com
Date: Wednesday, December 29, 2010, 7:57 PM
-James
> www. DiN. org. uk
> www. vu-us. com
> Hi Bakis,
> All the best
> Andy
>> hi Andrew,
>> thanks,
>> Bakis.
>> www. DiN. org. uk
>> www. vu-us. com
>> Hi Guys,
>> Thanks for any help
>> Andy
