> yes, try to check the jack from the back.
> i have heard of one guy, who had a tiny bit
> of dust in a jack, which caused funky things,
> so check for that too, also on the pcb.
> good luck :)
> best wishes
> ingo
> --- In Doepfer_a100@yahoogroups.com, "skp_pete" <skp_pete@> wrote:
> > thanks for the help
> > i bet youre right
> > i'll double check the plug to the bus board ( cant imagine those plugs come loose )
> > otherwise i can prob visually check the jack i guess from the back?
> > it was on all day today with no issues
> > --- In Doepfer_a100@yahoogroups.com, "selfoscillate" <synaptic_music@> wrote:
> > > the cv1 jack is normalled to the cv bus,
> > > maybe there is something wrong with the
> > > jack itself or with its bus connection?
> > > best wishes
> > > ingo
> > > > I've had my A-100 synth (started with basic system mini) since new only 5 months ago....
> > > > Yesterday after switch on, one of my A-110 osc sounded like it had random voltages going on inside?
> > > > It sounded really sick in the guts
> > > > no patch leads apart from the osc output so was definately something not right....
> > > > my other A-110 was and is fine.
> > > > after fraking out for a coupla minutes, i plugged a lead into CV1, and everything's fine. Take the lead out and everything is fine.
> > > > The same thing happened again today about 1-2 hours after start up.
> > > > the osc goes all sick sounding ..... i plug an unconnected lead into CV1 breifly and everything is fine for the rest of the day (another 8 hours)
> > > > what gives???
> > > > any help or experience??
> > > > thanks
