Doepfer
Compressor / Limiter
2010-08-15 by gruiere
is thee any chance of a commpresor / limiter module coming up!???
Re: [Doepfer_a100] Compressor / Limiter
2010-08-15 by Florian Anwander
Hello
Yes I often thought about, whether such a module would be good. Should
it be volage controlled and - if yes - which parameters should be
voltage controlled?
Especially, since one can achieve a compressor function using the A119
with a slewlimiter, an inverter and the standard VCA.
Florian
Re: Compressor / Limiter
2010-08-15 by Rudy
>Until Doepfer come up with a real compressor check out the VC-FCS of Cwejman
It is a bit pricy although very efficient. I just love the side chain
