Re:Kinda Newbie
2010-05-03 by zaum
> Typically, I jumped in headfirst, bought a 9u case and bought a > bunch of random crap on eBay. I have a row full an I still don't > have an oscillator! > > Do you have any FAQs here so I don't blow the damn thing up? I need > a mentor. If you take things literally about damaging modules I guess main danger is installing the ribbon connectors of new modules upside down. I can't think of anything your Doepfer System, Moog or Korg can generate with patch that's dangerous to another synth but there is a degree of danger from other gear when it generates higher voltages, though it's very rare. I'd say for better or worse nearly all people who've damages something did it through wrong power connections not interfacing CV. The only thing I can think of that's potentially trouble is some vintage gear used voltages higher than +10v. I can think of +15v gates on early Roland gear being used somehow or perhaps do it yourself sorts of gear that might sum multiple voltages together into a voltage well above the working range. If you use a proper modular mixer like one from Doepfer then that won't happen as the maximum output will stay within safe limits. Looking at damaging something else. With the exceptions mentioned, modular gear expects a good range of voltage so it won't be damaged by funny patches. I could think that sending very high DC control voltages into some standard audio equipment might be a bit much. But really damaging modular gear with other modular gear by accident is very rare. > > A quick question: which makes more sense? A midi to cv module or a > 351 for my Moog to use it as a controller? I would think there would be certain advantages to buying both eventually. Ideally you might want to combine the two as a modular system or use them individually. I think you might want to choose the VX-351 to let you get the most of combining the Voyager and the Doepfer. You may eventually want both so you can use each separately and combined but with what you have now Unfortunately the VX-351 does not let you "patch out" everything on the Voyager but it does give you many connections you could work with. Perhaps you might want to post the list of modules you have. Many people here are great at making suggestions of kinds of modules you might need or perhaps ways existing modules can do double duty. For instance, as you might already know some filters can self-resonate producing typically sine waves and respond to CV for pitch. Another option if you use a computer with your gear is Volta or Silent Way software. It takes a fair amount of time and potential frustration setting up as well as usually some custom cable connections of one kind or another but these solutions let you use channels on an audio interface to send CV and gates to synths that use them. They also let you calibrate wayward VCOs provided you have enough channels to dedicate one. Having a CV interface that has enough channels (with a needed Hz-V and Korg gate option which not all interfaces have) to operate the MS-20 might be a good thing too. It really depends on how much interfacing you think you want to do and use. -Nick
