Initial gain (was) Re: DIY Synth Group
2010-03-30 by zaum
I've definitely heard retold stories of Arp Odyssey's being returned as broken because the VCA slider was raised. It ranks alongside stories of monosynths being sent back because they only played one note at a time when you tried to play a chord. Rick Wakeman still tells that story of being given a "broken" minimoog. Though admittedly the initial gain concept requires some actual knowledge to grasp and use. As for "hold" etc. that a couple people mentioned. It's well known that numerous musicians resorted to sticky tape, weights, knives, etc. to get their synths to play drones for what it's worth. I would think a special "hold" function sometimes seen stems partly from Minimoog experiences though the availability of LFO to VCO modulation practically requires a pot imho. To me, I quickly grasped the concept. The vast majority of LFOs swing positive and negative. VCAs just work with positive values. If you want to patch an LFO to control the the VCA you will need one with initial gain if you want to hear the whole wave rather than the positive portion then nothing for a half cycle. If you don't have a routing for LFO to VCA to begin with then I can follow why a designer would leave it off. > This just comes to my sight: Initial Gain does not make sense at > polyphonic synths, because you would have humming all voices all the > time - no matter, whether their actual note fits in the played > chord or not. I agree with monotimbral synths. Though in the 90s before modulars were common again, I started reading about people sharing stories about playing Oberheim Xpanders without the keyboards. Being matrix modulated and multitimbral meant you could get some complex layered self playing patches going. That gets me thinking, if only I had a mod to route the output of one voice into another. That would really xpand it's potential... but anyway... I just thought I'd share what I've heard on the subject. I do wonder how, without a work-around, like a mixer with offset or a separate DC source one would work with LFO to VCA on a little system and hear the whole sweep of the LFO.
