Doepfer
MIDI ---> LFO
MIDI ---> LFO
2009-12-26 by deividnb1
Hi to all!
I was wondering if there is a way to sync an A-147 with an A-190 MIDI interface. The idea is to make the LFO oscillate at the same speed as the MIDI clock, to the modulation locked to the tempo of an external device.
Best regards,
David
Re: [Doepfer_a100] MIDI ---> LFO
2009-12-26 by achtung_999
The a191 has a simple (digital) LFO that can sync to midi clock. Should work
ok.
Otherwise it is possible to do it by tuning the a147 on ear. And giving it a
reset once every so often using a clock divider tapping from the midi clock.
This is not a plug and play solution, but if you wanted that you should
probably have used a soft synth
On Sat, Dec 26, 2009 at 3:18 AM, deividnb1 <deividnb1@yahoo.com> wrote:
> Hi to all!
> Best regards,
> David
I meant the A190 of course..
On Sat, Dec 26, 2009 at 6:46 AM, achtung_999 <
> work ok.
> a reset once every so often using a clock divider tapping from the midi
> clock.
>> Hi to all!
>> Best regards,
>> David
