Doepfer
Will Doepfer ever release the EMS filter - Unlikely read below
2002-07-10 by David Salter
Analogue systems/EMS collaboration
Analogue systems are pleased to announce the successful negotiations with legendary U.K synth manufacturer EMS a licensing agreement to produce certain classic modules to compliment the integrator range.
These modules will bear the EMS name and will faithfully reproduce the circuitry of the EMS VCS3 and synthi a.
The modules will incorporate all the modifications and updates that EMS undertook over the years with EMS allowing full access to the schematics and files to analogue systems designers.
The first modules will be EMS synthi filter which will incorporate the 18db/24db toggle switch which represents pre 1974/post 1974 changes so the user can decide from what era he wants the filter to emulate. voltage controlled resonance will be available because this was incorporated on the circuit boards but mot implemented on the synth itself.
The next module to be manufactured will be the a on d off trapezoid envelope generator again with all the official mods to stabilise the circuit to increase its usefulness.
If these first two modules are successful then there is a possibility of the two companies working on a joint project to create the super synthi with separate signal and control matrices, dual joystick controllers ,midi etc.T
 he first module should be available by September.
This was take from Analogue Systems website www.analoguesystems.com
David Salter
Reuters Consulting
Tel: +44 20 7542 2402
Mob: +44 7990562402
Fax: +44 20 7542 2699
        Visit our Internet site at http://www.reuters.com
Any views expressed in this message are those of  the  individual
sender,  except  where  the sender specifically states them to be
the views of Reuters Ltd.
