Digital BW, The Print
OBAs compared
OBAs compared
2010-01-17 by pr_roark
I've posted a graph of the paper white Lab B values for 2 brightened RC papers tested by Aardenburg Imaging.  The Lab B values in a brightened paper will increase as the OBAs fade, mostly due to oxidation.  This fading of OBAs will appear to make the papers "yellow" relative to their initial tones.  I wanted to see how a premium paper might compare to a paper that is less expensive.  I chose Epson Premium Luster and Red River UltraPro Gloss for the comparison.  See the graph at http://www.paulroark.com/BW-Info/OBA-compare-Eps-RR.jpg
I've discussed the results with Mark at Aardenburg Imaging, and he thinks the initial dip in Lab B values for the Epson paper is probably within what might be caused by normal read variances.  I was speculating that maybe Epson had employed some sort of counter-fade strategy (intentional fast fading yellow to offset the initial OBA fade).
Mark thinks the major factor that distinguishes the results is that OBAs are often put in 2 locations.  The ones under the barrier of the RC papers are better protected from oxidation, which causes the fade.  OBAs are also often put in the coating above the RC barrier, where they are much more exposed to oxygen and fading.
Assuming that explains the initial differences, it's interesting that the premium and less expensive papers exhibited almost identical OBA fade after the initial 20 MLux Hours of exposure.  It certainly seems that the OBAs under the RC barrier are essentially the same.
Paul
www.PaulRoark.com
Re: OBAs compared
2010-01-18 by Mark
Paul used the raw CIELAB data in two AaI&A light fade test reports to do a very creative analysis of optical brightener activity in two different papers. I'm impressed.
The moral of the story is that the susceptibility of the OBAS to light induced-fading in both papers (and probably gas fade induced fading as well) was comparable, but the one that used a high concentration of OBAs in the top coating layer (i.e, the Red River Paper) took an initial hit that didn't happen to the paper that deployed similarly vulnerable OBAs in subbing layers or paper core only. In other words, the inherent molecular structure of the OBAs used in both papers may very well have been identical, but their location and concentration influenced the final light-induced fading appearance.
The practical outcome is that papers with high OBA content, especially in the top coat layers, will register strongly negative initial b* values on spectrophotometers or colorimeters using gas filled tungsten light sources and no UV cut filters, and they will appear to the human observer as strongly "cool white" in appearance under any light source with moderate or high levels of UV content.  Light induced or ozone gas-induced "burn off" of the high OBA content fluorescence will then result in easily noticeable "yellowing" on the strongly brightened papers whereas papers that use the OBAS more judiciously will exhibit less apparent "discoloration" over time because the OBAs played a smaller role in initial whiteness of the paper.
kind regards,
Mark
http://www.aardenburg-imaging.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark" <paul.roark@...> wrote:
> Paul
> www.PaulRoark.com
Re: OBAs compared
2010-01-18 by pr_roark
I've posted a second graph of paper Lab B fade test results from Aardenburg Imaging.
See http://www.paulroark.com/BW-Info/OBA-Comparison-2.jpg
In this one I've expanded the papers, which now include Epson Premium Luster, Red River UltraPro Glossy, Red River Polar Matte, Epson Premium Presentation Matte, Hahnemuhle Photo Rage, and Red River Aurora Natural.
Previously Mark noted that the OBAs that were protected by the RC paper barrier would oxidize more slowly.  As such, it makes sense that matte paper OBAs would be more exposed and oxidize faster.  See the graph lines for Red River Polar Matte and Epson Premium Presentation Matte.  They do seem to be oxidizing and fading faster, causing the papers to have increasing Lab B values (getting relatively more yellow) faster than, particularly, the Epson Premium Luster.
One interesting result is the similarity in the Lab B changes for the Epson Premium Presentation Matte and Red River Polar Matte.  It looks like the main difference may be that the underlying Red River paper has a lower (more neutral) Lab B.
Note also that the H. Photo Rag seems to have very little OBAs in it and a paper base that is rather bright by nature.  It and the Red River Natural are not much different.
(Note that the initial reads with a number of these papers may be higher due to some artifact of the testing.)
Thanks to Mark and his testing at Aardenburg Imaging -- http://www.aardenburg-imaging.com/ -- we have much more information available to us to understand and compare our materials.
Paul
www.PaulRoark.com
