Digital BW, The Print
actual print sizes
actual print sizes
2010-01-14 by wlh_1
For no particular reason the other day I measured the actual size of the prints that I was getting from my R280 printer. I found that the actual print size was about 1/16 inch smaller than the input file said it was. That is an 8 x 10 image was about 1/16 inch smaller in length and width. Has anyone else noted this and if so has anyone any ideas why?
I have done the same test on an R220 and a 1400 with the same results using both the Epson driver and QTR.
Re: actual print sizes
2010-01-15 by ClaytonJ
Hello Will,
I use a 2400 and have always gotten exactly the specified dimensions.  I just checked again to be sure.
Clayton
I-Trak 2.1   http://www.cjcom.net/itrak.htm
2010-01-15 by William Harvey
Clayton,
I re-checked measuring from 1 inch to 9 (for the 8 inch side) and see
exactly the same reading... 1/32 short! I have a 2400 and I guess that I
will try it but that means firing it up after a long period of no use...
a good excuse to get it going again.
Cheers
Will
Clayton writes:
Checked by AVG - www.avg.com
Version: 9.0.725 / Virus Database: 270.14.138/2618 - Release Date: 01/12/10 23:35:00
