Digital BW, The Print
linearize ABW cool/warm tone with QTR profile?
2007-06-07 by David Keenan
Okay, now that I am (finally) getting up a learning curve that I didn't know
existed, I have an other question.
I did a ABW QTR ICC profile using the "neutral" ABW mode. And then on a
later test print, I did see an improvement.
Now I wonder if if makes sense to create a separate profile for "warm",
"cool" (or any other custom) ABW mode?
Seems like the answer should be yes -- but do I wonder if when printing at
something other than "neutral" if this is inherently non-linear anyway and
an ICC profile would try to flatten things out resulting in the (some?) loss
of the toned affect.
If the above it true then any ABW print should be made using the neutral ICC
profile and driver would work off of that to create the toned affect.
Can someone set me straight?
Dave.
Portfolio: www.david-keenan.com/portfolio
Web Site: www.david-keenan.com
2007 PAW: www.david-keenan.com/paw
Re: linearize ABW cool/warm tone with QTR profile?
2007-06-07 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "David Keenan"
yes, it does
printing at
anyway and
(some?) loss
no, because there is no way to effect the ABW driver's print color by
altering the data sent to it, only by changing it's settings directly.
Linearity is a different matter as you've discovered.
neutral ICC
no, because Epson didn't necessarily do a wonderful job retaining the
exact same linearity out when changing hue settings. I believe some
testing by users here when it first came out verified that.
Tyler
Re: [Digital BW] linearize ABW cool/warm tone with QTR profile?
2007-06-08 by Ernst Dinkla
It makes sense as the ABW tone range shifts with color
toning added. For that reason some will use say 3-4
profiles, each for a different color tone. The softproof of
each represents the color of the print too. Usually this
represents more or less how prints in the old darkroom were
used and one kept the color choices to a minimum.
As I print for others I'm not so happy with that restricted
choice. I want to keep the flexibility of the ABW system +
keep profiling. I have the neutral profile (HP Z3100 with
its neutral black ink range) but have to make an average
profile for mild color toning. Best method will be to print
several targets and average them like the 4x21 random step
target can be averaged. Strip the reading of its a b
components and use that as a tone range control for not too
excessive color toning. I know that that will be a
compromise. It will not have the color softproof either but
it gives some freedom in selecting color.
Met vriendelijke groeten,Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
