Kudos, Paul Roark!
2007-01-04 by guy_staley
I've just started using your profiles for the Crane Silver Rag paper, and the results are outstanding! Thank you! Thank you! Thank you! Now I'd like to begin tweeking those profiles, but I'm still a bit confused on how to manipulate the curves. For instance, I'd like to create a "warm" version, and a "cool" version, but I'm not sure how to start. I've opened the curves in CS2 and examined the RGB channels. I have a basic understanding of what's happening, but alas, I'm still in a fog as to how to move forward. Also, I'd like to relinearize these profiles for my own equipment. I have Roy's Create ICC program suite, and I understand the basic gist. I'll be using a scanner and CS2 to read the densities. I've calibrated my scanner using a Kodak Gray Scale, and have succesfully generated a curve in Create ICC, but I'm a little unclear as to how to go about RE- linearizing and existing curve. Again, much thatnks for all your hard work, and your outstanding profiles! Sincerely, Guy Staley Seattle, WA
