Digital BW, The Print
Epson R2400 Guaranteed No Color Cast
2006-11-14 by eddiegnz1
question from not a photo newbie but a B&W newbie...Why can't you just
take out the 5 color cartriges and leave in just the 3 black ones to
guarantee yourself no color cast in the R2400?  and why does the
advertisement on the R2400 say 9 ink cartrages?  can you really have 9
ink cartriges all going at once?  if so, can you have 4 black cartriges
and leave out the 5 color ones?
thanks for helping
Eddie
Re: Epson R2400 Guaranteed No Color Cast
2006-11-14 by Clayton Jones
Hello Eddie,
The printer won't run without all carts in place, so you have to have
_something_ in them.  But there are some all-gray inksets for the 2400
available from  inkjetmall.com
Clayton
I went to www.inkjetmall.com and is it safe to assume that the thing
to buy would be the
("Piezography Neutral K7 inks for Epson Stylus 2400 -Set of 8
cartridges")
To me it's not 100% clear but it seems like this so called K7 kit
includes 8 cartriges but none of them are color cartriges but are
designed for a specific slot on the Epson R2400.  For example, there
is a neutral grey ink designed for the yellow postion.  is that
right?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones"
<cj@...> wrote:
> Hello Eddie,
just
to
have 9
cartriges
have
2400
> Regards,
> Clayton
Eddie,
>to buy would be the ("Piezography Neutral K7 inks for Epson Stylus
>2400 -Set of 8 cartridges")
>right?
Yes, I think so.  I haven't used them so I can't say for sure, but
that sounds like the right one.  I think there is also a Sepia version
of them (it's not a variable tone system, so you have to buy warm or
neutral versions).  Hopefully someone who knows more about it will
come in here with more details.  It might be good to hold off ordering
them until you have all the right info.
Clayton
2006-11-14 by Mark Stracke
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "eddiegnz1" <eddiegnz1@...>
> right?
The Neutral K7 set was originally made for the 2200, which only has 7 positions. It has a
black plus 6 dilutions of grey. There is no color as such (no yellow cyan etc.) In printers
with more than 7 positions they add a "Power Flush" cart for the extra slot.
The set was designed to be measurably neutral on Photo Rag paper. Using the inks on
other papers will impart an apparent color to the inks. On Inkjet Mall's "Bradford Brilliant
White" the inks will seem to have a selenium color. And on Innova Cold Press Art paper
they will seem to be warmer. You can also buy a Sepia toned set of the inks, or just use a
Sepia in  a few positions for a split toned effect. It's fairly easy to swap out carts since the
print head doesn't hold much ink in the smaller, desktop printers (2200, 2400, 1800 etc)
and the switch over happens pretty quickly, although you do burn through some ink.
The inks are set up to be used with QuadTone Rip, which comes with curves already made
for these inks. Check to see if your favorite paper is supported by QTR. Use those curves
rather than making your own unless you really know what you're doing. Cone and Co have
made very nice curves that can be made to print super smooth and subtle, or you can jazz
up your files and print a very contrasty look if so desired. You can't print on glossy paper
with these inks, only the matte surface art papers.
Now the one wild card in this is human perception. Cone's crew used a colorimeter to
measure each dilution of the neutral set and they were tuned to be measureably neutral on
Photo Rag paper. Each person's eyes will see this differently though, so you might not
perceive the inks to be neutral. Inkjet Mall has a set of samples on a variety of papers that
one can order and look things over before buying. Or for the $130  give the inks a try.
Mark Stracke
