Re: [Digital BW] Blending to Paper White
2006-11-13 by CDTobie@aol.com
In a message dated 11/13/06 5:16:21 AM, joemulligan_68@... writes: > I've seen C. David Tobie mention that the new Print Fix Pro 2.0 has a > function where the > printer has the option to blend to paper white. I want to ask what is the > exact definition of > this. > In PrintFIX PRO 2.0 the software does what it thinks is best automatically, via one of two algorithms: Paper Relative Grays (the default choice, where the grays are based on paper white) or Absolute Grays (a checkbox option, where the paper tone is not factored into gray definitions). If the Paper Relative Grays function does not give you just what you want, for the grays you are using, or the way your paper appears under your lighting, you can adjust the way grays (and other tones, but grays are most picky) ramp to white, by adjusting sliders that bias the tint near white, and taper off as tones get darker. There are three of these tinting sliders (since you are working in RGB space), and some amount of adjustment to one, or to two of them should result in the tonality you want. This will, theoretically, be previewable in our PrintPreview screen after building the adjusted profile, but I find paper white effects to be the least effective part of softproofing, so I suspect you will want to print the B&W test image to see if the profile now has the highlight tint you are looking for. C. David Tobie Product Technology Manager ColorVision Business Unit Datacolor Inc. CDTobie@colorvision.com www.colorvision.com [Non-text portions of this message have been removed]
